TSB 11-1-5 Canister Purge Valve
Discussion in 'Ford Raptor Recalls | TSB's | SSM's' started by pirate air, Feb 5, 2011.
  1. intow
    intow Full Access Member
    50
    98
    62
    Jun 14, 2014
    Louisiana
    I have a 2013, no ticking but it takes 3- 5 seconds to start every time I fill up. Also get a check engine light soon after a fill up (usually but not every time). Can't remember the code but it translates to "very small vacuum or emission leak). Guess I'll try changing this out when I get back home and see if it fixes it.
  2. RaptorVette
    RaptorVette Full Access Member
    225
    82
    Oct 12, 2012
    Corpus Christi, TX
    Thanks for the post! I just had my truck with 75k miles get a P0445 code and just replace the purge canister and the codes gone!
  3. Raptors4ever
    Raptors4ever Member
    39
    43
    16
    Nov 4, 2016
    Hillsboro, OR
    so what is the difference in the below part #s?
    9U5Z-9C915-BE
    CX2409
    CX2383
    other than the price they seem to be the same parts unless one is the more up to date version?
  4. dhanni848
    dhanni848 Full Access Member
    64
    8
    May 20, 2016
    Nashville, TN
    In for that answer too since I think I am coming up on this issue.
  5. Raptors4ever
    Raptors4ever Member
    39
    43
    16
    Nov 4, 2016
    Hillsboro, OR
    anyone have any idea?
  6. engine45
    engine45 Full Access Member
    169
    47
    Apr 23, 2014
    South Florida
    I put a dorman 9U5Z9C915BE in my truck around May 2016. Haven’t had and issues with it if that helps. Bought it on Amazon. And Amazon says the CX2409 doesn’t fit our trucks.
  7. Raptors4ever
    Raptors4ever Member
    39
    43
    16
    Nov 4, 2016
    Hillsboro, OR
    Interesting as I just went to Amazon to check and when I put 2013 Ford Raptor 6.2L I get 9U5Z9C915BE does not fit your vehicle but CX2409 does. Pretty sure I did this before leading me to post my prior question. So confused on what in the hell is going on and what part is the correct one now.
  8. engine45
    169
    47
    Apr 23, 2014
    South Florida
    Rechecking my purchase i put on a dorman 911-283 and it was identical to the one I pulled off. If that helps
Share This Page
