TSB 10-24-1 5.4L Surge When Cold
pirate air
will plunder your booty
TSB 10-24-1
12/16/10
5.4L 6R80 4X4 - SURGE WHEN COLD ONLY
FORD:
2010 F-150
ISSUE
Some 2010 F-150 4X4 vehicles equipped with 5.4L engine and 6R80 transmission built on or before 8/15/2010, may exhibit a 100-200 RPM surge when cold only. This condition may be present at road speeds between 25-35 MPH (40-56 Km/h), engine speed between 950-1100 RPM only and will not be present once transmission fluid temperature reaches 104 degrees F (40 degrees C).
ACTION
Follow the Service Procedure to correct the condition.
SERVICE PROCEDURE
1. Reprogram the powertrain control module (PCM)/transmission control module (TCM) calibration using IDS release 69.01 and higher. This new calibration is not included in the VCM 2010.9 DVD. Calibration files may also be obtained at the website.
NOTE THE TCM CANNOT BE INDEPENDENTLY REPROGRAMMED.
2. Reprogram using the PMI function to ensure that engine and transmission calibrations are updated to the latest level simultaneously.
a. Verify that the TCM Calibration is:
AL3P-7J104-BD for F-150 4X4.
b. Select the following from the IDS tool:
(1) Toolbox
(2) Powertrain
(3) OBD Test Modes
(4) Mode Level 9 Vehicle Information
(5) TCM Cal Part Number
3. Clear TCM keep alive memory (KAM) and adaptive table
NOTE IT IS CRITICAL THAT 1CM KAM BE CLEARED FOR THIS PROCEDURE TO BE FULLY EFFECTIVE
a. Using IDS:
(1) Open Toolbox
(2) Choose Powertrain Then Choose 1CM
(3) Choose Reset KAM
b. Using PDS:
(1) Choose all Tests and Calibrations
(2) Scroll down the menu and choose reset TCM KAM
NOTE FOR PDS, RESET TCM KAM IS NOT THE SAME AS CLEAR TRANSMISSION ADAPTIVE TABLES, WHICH IS UNDER THE POWERTRAIN - TRANSMISSION MENU TREE.
NOTE UNHOOKING THE BATTERY WILL NOT CLEAR THE TCM KAM. IT IS CRITICAL THAT TCM KAM BE CLEARED PRIOR TO RELEARNING THE ADAPTIVE TABLES FOR THE TRANSMISSION.
NOTE DO NOT CLEAR THE PCM KAM.
4. Verify that the transmission fluid temperature (TFT) PID is above 175°F (80 °C). If it is not at 175 °F (80 °C), drive unit approximately 3 miles (5 Km) to reach temperature. TFT must be at 175 °F (80 °C) or above before proceeding to Step 5.
NOTE PERFORM ADAPTIVE SHIFT STRATEGY LEARN ON LEVEL SURFACE ROAD.
5. Drive unit to perform adaptive shift strategy learn.
a. Accelerate from a stopped position with light throttle to 15 MPH (24 Km/h) and remove foot from accelerator pedal.
b. Brake very gently to a complete stop, allow at least six (6) seconds.
c. Repeat steps (a-b) five (5) times in the dealership parking lot or similar setting.
d. Accelerate from rest with light throttle ensuring that the 1-2, 2-3 and 3-4 shifts occur at engine speeds between 1700-2000 RPM
e. Continue to accelerate until you achieve 50 MPH (80 Km/h) or the 5-6 upshift.
f. Brake gently to a complete stop and hold foot on brake for ten seconds.
g. Repeat steps (d-f) three (3) times
NOTE SEVERAL DAYS OF DRIVING ARE REQUIRED FOR THE TRANSMISSION TO FULLY ADAPT.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
102401A 2010 F-150 4X4 5.4L 3V 1.0 Hr.
6R80 Transmission: Check
DTCs, Reprogram The
PCM And TCM, Includes
Time To Clear KAM And
Perform Road Tests (Do
Not Use With Any Other
Labor Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
RECAL 42
