TSB 10-18-1
09/27/10
5.4L WITH 6R75/6R80 - DELAYED
FORWARD/REVERSE ENGAGEMENT - DTCS P0741,
P0731, AND/OR P0735 - AFTER COLD START
FORD:
2007-2010 Expedition
2009-2010 F-150
LINCOLN:
2009-2010 Navigator
ISSUE
Some 2007-2010 Expedition, 2009-2010 Navigator and F-150 vehicles equipped with a 5.4L engine and a 6R75/6R80 transmission may exhibit delayed forward/reverse engagement. Diagnostic trouble codes (DTCs) P0741, P0731, and/or P0735 for torque converter and/or gear ratio concerns may be stored in the powertrain control module (PCM). This concern typically occurs after cold start and in colder climates.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Remove the mechatronic assembly. Refer to Workshop Manual (WSM), Section 307-01.
2. Inspect the fluid pump adapter seal molded frame for evidence of cracks, which are most often found in the corner(s) of the molded frame.
a. If evidence of cracks are present, proceed to Step 3.
b. If evidence of cracks are not present, do not continue with this article. Refer to WSM Section 307-01 for further diagnostics.
3. Partially disassemble the mechatronic assembly to access only the main oil pressure regulator valve located in the lower half. Refer to WSM, Section 307-01.
4. Inspect the main oil pressure regulator valve for free movement in its bore.
a. If the valve moves easily in the bore, proceed to Step 5.
b. If the valve does not move or sticks, remove the valve and clean both the valve and bore, reinstall the valve. Proceed to Step 5.
5. Reassemble the mechatronic assembly. Refer to WSM, Section 307-01.
6. Install a new front pump adapter seal.
7. Reinstall the mechatronic assembly. Refer to WSM, Section 307-01.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
101801A 2007-2010 Expedition, 2.7 Hrs.
2009-2010 F-150,
Navigator: Follow Service
Procedure To Repair
Mechatronic Includes Time
To Remove And Install
The Mechatronic And
Reprogram (Do Not Use
With Any Other Labor
Operations)
09/27/10
FORD:
2009-2010 F-150
LINCOLN:
2009-2010 Navigator
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
2009-2010 F-150,
Procedure To Repair
The Mechatronic And
Operations)
