Trouble installing lights
coachhomer
Please see the attached photos. I have the rigid industries bracket and it doesn’t seem to be fitting properly. 2012 Raptor. The straight edge is lined up with the beam at the step down. There isn’t any room for the light to move up or down. It is sitting flush on the bumper. Anyone else have this issue?
C
coachhomer
Another picture from the driver side. You can see the hole to the bracket almost lines up with the hole in the beam. That doesn’t seem right. How am I supposed to drill a hole where there is already half of a hole?
Baja Designs
Rigid Industries probably designed their bracket for their lights, that may be the reason you're running into mounting issues with our product. Unfortunately, I don't have much insight on a solution without modification to the bracket. Although, we do have a bracket that works with the Squadron and the 2012 Ford Raptor. https://www.bajadesigns.com/products/ford-raptor-10-16-fog-pocket-mount-kit.asp
