- Joined
- Jul 15, 2017
- Posts
- 1,039
- Reaction score
- 933
For a limited time, in addition to the sale prices:
Add a 2nd Gen Raptor Fog Kit to Cart, and add our new Pro Plug N Play Weather Proof Harness kit to cart, and the harness kit will be Free. ($69.99-$84.99 Value)
or
Add a Rear Light Kit to cart and add our new Plug N Play Tail Light Adapter to cart and it will be Free. ($44.99 Value)
Here are links to the compatible Fog kits (Note: Radiance/Scene/360 kits are UPGRADED from their standard included harnesses with this offer)
Radiance/Scene
Rigid 360 Round Series
Rigid Pro Series
Rigid Pro Midnight Spot Series
Baja Designs Sport Series & Baja Designs Pro Series
Then add the harness to cart- (Choose your correct adapters, but if you mess up, we will send the right ones)
Here are the Rear Kit Links-
For the rear kits, here are the links to the compatible kits. (Note: We will upgrade you to the New Harness System automatically when you add the rear adapter to cart for the free offer.) (These rear kits include the FULL length harness to your switches. The tail Light adapter will give you BOTH reverse trigger and switch power on demand)
NOTE; Select the option "FULL REAR HARNESS ONLY" as you will be be adding the adapter for free.
Radiance/Scene
SRL Rear
Rigid Pro Flood
Baja Designs S2
Then, add the adapter -
For those not familiar, we at SPVparts.com strive to design and manufacture the best components for your Raptors and other vehicles. Whether its our Triple Fog brackets with the most advanced movement and adjustment in ANY direction, but not just in straight lines... they contour with the shape of the bumper. Or the fact they are high grade stainless steel with black powdercoat. We provide the best.
Or, or Universal Plug N Play Harnesses that take ALL the guess work out of wiring up your lights. Our new harness system is patent pending and is the most advanced plug n play harness you can find. It will plug into ANY light or Combination and includes matching weatherproof plug n play connectors for your switch wires! They were featured on the Motor Trend Network for their ingenuity.
Feel free to contact us with questions-
317-934-6778
info @ spvparts.com
or
Radiance/Scene
SPECIAL BUY - SPV Parts 2017-2020 Ford F-150 Raptor - Rigid Radiance/Scene Fog Amber LED Triple Fog Light Kit Including Brackets (20204 & 68204)
Purchase a new set of amber LED fog lights for your 2017, 2018, 2019, 2020 Ford Raptor online at Specialty Performance Parts! These lights come with mount brackets.
specialtyperformanceparts.com
SPV Parts 2017-2020 Ford F-150 Raptor Rigid ROUND 360 Series Triple Fog Light Kit Including Brackets (Front Only) - LED Lights
Rigid Industries Radiance lights have taken the market by storm, now add them to your 2017-2019 Raptor! Our Radiance Light Kit will provide you with the look you've been searching for with a quality you can find anywhere else! Purchase yours today to see what you've been missing out on!
Rigid Pro Series
SPV Parts 2017-2020 Ford F-150 Raptor Rigid PRO Triple Fog Light KIT
Purchase a Rigid Pro fog light kit for your 2017-2019 Ford Raptor online at Specialty Performance Parts! This kit comes with your choice of light combinations.
SPV Parts 2017-2020 Ford F-150 Raptor Rigid Industries PRO MIDNIGHT SPOT Fog Light KIT (202213BLK)
Customize your Raptor with the SPP Pro Fog Light kit! This kit includes a pre-configured Rigid D-series pro light selection, and our custom SPP fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your Raptor...
SPV Parts 2017-2020 Ford Raptor Baja Designs Sport & PRO Triple Fog Light Kit (With Brackets)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Baja Designs pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
SPV Parts Triple Pair Fog Harness - SPV Harness System (Works with MANY vehicles, See Details)
Triple Pair Fog harness MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in 1,2,3 Lights on one side, then 1,2,3 on the other. This is a direct component harness to connect 3 pairs of lights/Fog Lights to ANY Ford Raptor, or Ford Superduty, Bronco, ETC with built in switches. OR...
Radiance/Scene
SPV Parts 2017-2020 Ford F-150 Raptor RED Rigid Radiance Reverse Light Kit Backup LED Kit (20202 & 68202)
Pick from the Rigid Industries Radiance, or Radiance Scene versions: The Standard Radiance and the Scene versions have the SAME effect. The Backlight (Amber or Red) is the same. The Differences are this- Radiance- 1 LED Per Pod (2 total) Scene – 4 LED’s Per Pod (8 Total) Radiance Lumens – 900...
SRL Rear
SPV Parts 2017-2020 FORD F-150 RAPTOR RIGID REAR SR-L SERIES REVERSE LIGHT KIT (NO DRILL) SRL rear light kit
Purchase new Rigid reverse lights for your 2017-2020 Ford Raptor at Specialty Performance Parts! Our light kit comes with your choice of harness.
Rigid Pro Flood
SPV Parts 2017-2020 Ford F-150 Raptor Rear Rigid Pro Light Backup Kit with Rigid Industries Pro Flood Lights #202113
Specialty Performance Parts EXCLUSIVE 2017-2020 Ford Raptor backup kit is ready for your Raptor! This kit uses 2 Rigid D-Series flood lights for maximum coverage and illumination behind your truck! Don't sit in the dark! Pick yours up today and join the SPV family!
Baja Designs S2
SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit
NEW! SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit The New SPV Raptor Reverse Light kit utilizing the Baja Designs S2 lights are Here!! The advantage to these is the extra slim case. If you want similar light output and less bulk...
SPV Parts Harness Taillight Connector Adapter (Powers Reverse Lights/Backlights) - SPV Harness System (Works with MANY vehicles, See Details)
Tail Light Adapters MAIN APPLICATION/DESCRIPTION- These add on adapters connect to the factory tail lights of MOST vehicles. (More makes/models coming soon) You simply plug the adapter into your tail light, and the factory harness into it. The other end connects to our FULL LENGTH Rear Harness...
317-934-6778
info @ spvparts.com
