Triple Bezel Fog Lights - No Longer Working
Discussion in 'Ford Raptor Problems and Questions Forum' started by Imoxfordwhite, Sep 23, 2020.
  1. Imoxfordwhite
    Imoxfordwhite Member
    9
    Jun 6, 2020
    Raining cats and dogs here in Houston this week and I had to unfortunately venture out yesterday. I was driving down a dark side road when I noticed only 1 single fog light was working. (Out of 6)
    Everything was working perfectly last week when I tested them, normal conditions.
    I have them wired up :
    Aux 1 - two outer small lights
    Aux 2 - two middle lights
    Aux 3 - two inner lights
    What's throwing me off is only one light works when I have Aux 1 activated and I get nothing when test 1,2,3. (I've tried multiple combinations with no success)
    Any idea where to start or what's the potential issue?
    Kit:
    OFFROAD ALLIANCE - TRIPLE BEZEL FOG LIGHT KIT W/ BAJA DESIGNS SQUADRON PRO
  2. TheTeej
    TheTeej Full Access Member
    37
    234
    141
    Jul 19, 2015
    Denver, Colorado
    Fuses for the switches maybe? You could try swapping the harness around at the working light to see if it works on the other switches.
  3. DanT
    DanT FRF Supporting Member Supporting Member
    156
    81
    Jul 16, 2019
    North Texas
    Check your fuses - double check your connectors to the switches - I had a bad one and kept blowing the fuse
  4. REX111
    REX111 Full Access Member
    67
    38
    Aug 11, 2020
    Sussex
    Check your grounds too.
  5. Imoxfordwhite
    9
    Jun 6, 2020
    Appreciate the suggestions
  6. REX111
    67
    38
    Aug 11, 2020
    Sussex
    It’s a light bulb. It only needs 12v and ground to light up. If you do have 12v and ground at the bulb then the bulb is most likely bad.
  7. Winchester30
    Winchester30 Full Access Member
    309
    278
    Oct 4, 2018
    Wi
    “Any idea where to start or what's the potential issue?”
    How about starting with OFA customer support, they’re excellent.
Share This Page
