Transmission updates - aftermarket pan and dipstick?
Cody Templeton
Des Moines, IA
Recently added the Full Race trans cooler and was thinking maybe there might be some other transmission upgrades that might be worth it. Was looking at aftermarket dipstick setups to be able to check the fluid from the engine bay instead of having to crawl underneath. Also wondering if an upgraded pan setup would be worth it as well. The trans dipstick kits range from something like this:
To something like this:
On the pan I'm not really sure who the go-to is, there's a ton of them available.
Gumby
Nashville
I just made tools to check and fill, I think I posted them somewhere. Here they are again.
Of corse the bag has been cleaned and filled with trans fluid. I fill the bulk with a pump my pan holds three, 5 quart jugs then use the bag to top the level off.
Tools are just a pice of break line and carriage bolt some rubber hose to hold the short dip stick.
TomDirt
Hesperia CA
They could have just used the next larger diameter braided hose so that products like the Mityvac vacuum pump tube could slide inside the larger hose. They've known about this since the 6R80 was first produced in 2005, yet not a single aftermarket company has done it.
TomDirt
Hesperia CA
FoMoCo claims these are "lifetime" transmissions, declaring the trans juice is good up to 150,000 miles, or 100K under "severe" conditions.
TAC71
Osoyoos BC Canada
I welded a -10 fitting on the right front corner of the trans pan. Made the dipstick tube out of -10 line with a section of metal tubing at the top. Got a dipstick out of earlier ford pu and built the tube to be calibrated to the length of the dipstick.
C
Cody Templeton
Des Moines, IA
Leaning more towards the aFe pan at this point since it holds 7 quarts over stock, which is the most out of any aftermarket pan out there.
