Pk64f100
Output shaft speed sensor circuit P0720 & P0722 codes came up when the truck would not leave 1st gear and speedometer was not working. I called dealer and they said they will repair and know what’s wrong The mechanic told my salesman who I purchased truck from in July that he has done this recall repair on some module in transmission. The truck also shifts a little hard at times. I hope this does fix the issues. When I purchased truck I asked the salesman to have all recalls done and he said that the dealership took care of all recalls which included a daft ware update on the transmission. Anyone have any experience with this issue and any information to help me ensure when I get truck back that it is repaired correctly? The reason I ask is that the dealership has had my truck 2 now 3 times to fix the power steering which makes some nasty noises when I turn 3/4- all the way to left They replaced Rack pinion but the HOWE pump seems to whine and then the rack makes the horrible noises like it binds up all the way to left
