Transmission gear numbers on dash
Alaska
Not sure why but before inside the tach used to show which gear you were in while driving in auto. It will still pop up for manual mode. Any one have this issue? I cant even remember last time I saw it. Plan on asking local dealer when I go in for service. 20190115_151238.jpg 20190115_151220.jpg
this is a bug. if you inadvertently hit the shifter buttons or paddles, the gear display goes dark. Hit the + paddle (again) and it comes back. It’s got to be some kind of easer egg put in by a Ford programmer who’s now laughing their behind off with all the online complaints about this.
Raptorguy1
This video shows it on a 6 speed, same way to restore the display.
HeavyAssault
Virginia
Not really a "bug" it's more as the video described. Just a way to darken/limit the display cluster if you choose.
I'm betting it's more a secondary result of the Progressive Range Selection feature.
Michaelgrimaud
Alaska
Worked on both my raptor and my wifes new expedition. Lol after reading all the comments I remembered this also happened to my 2014 fx4. Thanks everyone.
S Killius
Pensacola, Fl
I believe it does that to let you know you have locked out a gear. You'd think they would have just made the gears you locked out red so you'd know, but instead they just get rid of the display all together.
HeavyAssault
Virginia
The gear # displayed on the side being removed shows that the Progressive Range Selection (PRS) is not active. When using the PRS you will "deactivate" the "gear" you don't want to use during the transmission shifting.
I.E. If you are driving in a low speed trail section and you don't want to use 7th, 8th, 9th, and 10th gear use PRS to select "Down" or "-" on the console shifter.
Then the ONLY gears that the transmission would use are going to be 1st-6th.
Once you are done you would use the "+" to "activate" the aforementioned gears you chose to not use in the transmission shifting.
Transmission shifting would then go back to 1st-10th.
