I have this on the Maintenance Board, but no responses, so posting it here.
Planning on replacing the stock transmission pan with a B&M pan.
1. Does the transmission (6R80) converter have an oil drain plug like most other typical transmissions?
2. Anyone know how much fluid the converter holds?
3. When you are changing the tranny oil are you also draining the converter?
