Tpms new sensor pairing
cahek65
Primorsk
Hi, guys! I've got one of TPMS sensors dead in my 2013 Raptor with Sensor Fault message displayed in the dash. I ordered 2 new sensors from Ebay with the same part number as the old one(DE8T-1A180-AA). Having installed a new sensor and travelled over 50 miles I activated a sensor training procedure by pushing hazard button 6 times. 3 Old sensors identified successfully but new one failed to identify.
I used Ford TPMS training tool TPMS-19.
I tried the same procedure with the second sensor- no luck. I borrowed a scaner tool to test these sensors and it showed the correct temperature and pressure...
Did anyone encounter such a problem?
xtela
This is cut from the 2014 service manual. I think you may be using the reset procedure when you need to be using the training procedure.
NOTE: When directed to train or re-train any TPMS sensors, use only the sensor training procedure outlined in Tire Pressure Monitoring System (TPMS) Sensor Training . Do not use the TPMS reset procedure outlined in the Owner's Literature as this procedure will not program new sensors to the module.
Special Tool(s) Activation Tool, Tire Pressure Monitor
204-363
Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS)
software with appropriate hardware, or equivalent scan tool
NOTE: If the vehicle has been stationary for more than 30 minutes, the sensors will go into a "sleep mode" to conserve battery power. It will be necessary to wake them up so they will transmit the latest tire pressure information to the BCM . For additional information, refer to Tire Pressure Monitoring System (TPMS) Sensor Activation in this section.
NOTE: The Tire Pressure Monitoring System (TPMS) Training procedure must be done on a single vehicle, in an area without radio frequency noise and at least 1 m (3 ft) away from other vehicles equipped with a Tire Pressure Monitoring System (TPMS).
Radio frequency noise is generated by electrical motors and appliance operation, cellular telephones, remote transmitters, power inverters and portable entertainment equipment.
NOTE: If a sensor does not respond to the Tire Pressure Monitor Activation Tool, move the vehicle to rotate the wheels at least one-fourth of a turn and attempt to activate the same sensor again. If the sensor still does not respond, attempt to activate the same sensor again using the customer activation tool (if available). If the sensor still fails to train, attempt to train the sensor with the vehicle doors open.
NOTE: The BCM has a 2-minute time limit between sensor responses. If the BCM does not recognize any 1 of the 4 tire pressure sensors during this time limit, the horn will sound twice and the message center (if equipped) will display TIRE NOT TRAINED REPEAT and the entire procedure must be repeated.
NOTE: For vehicles with different front and rear tire pressures (such as the E-Series and certain F-Series), the tire pressure sensors must be trained following a tire rotation. Failure to train the sensors will cause the TPMS indicator to illuminate. For vehicles with the same tire pressure for front and rear tires, tire rotation will not affect the system.
NOTE: Refer to Description and Operation, Push Button Start System Ignition Modules in Section 211-05 to review the procedures for achieving the various ignition states on vehicles with this feature.
NOTE: An animated version of this procedure is available on-line.
Turn the ignition switch to the OFF position, then press and release the brake pedal.
Cycle the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position.
Press and release the brake pedal.
Turn the ignition switch to the OFF position.
Turn the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position.
The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN LF TIRE.
NOTE: It may take up to 6 seconds to activate a tire pressure sensor. During this time, the Tire Pressure Monitor Activation Tool must remain in place at the valve stem.
Place the Tire Pressure Monitor Activation Tool on the LF tire sidewall at the valve stem. Press and release the test button on the Tire Pressure Monitor Activation Tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the BCM .
Within 2 minutes of the horn sounding, place the Tire Pressure Monitor Activation Tool on the RF tire sidewall at the valve stem and press and release the test button to train the RF tire pressure sensor.
NOTE: Do not wait more than 2 minutes between training each sensor or the BCM will time out and the entire procedure must be repeated.
Repeat Step 7 for the RR and LR tires.
The procedure is completed after the last tire has been trained. When the training procedure is complete, the message center (if equipped) will display TIRE TRAINING COMPLETE.
For vehicles not equipped with a message center, successful completion of the training procedure will be verified by turning the ignition switch to the OFF position without the horn sounding. If the horn sounds twice when the switch is turned to the OFF position, the training procedure was not successful.
Using the scan tool, locate the updated TPMS sensor identifiers trained to the BCM and document them on the applicable warranty claim.
NOTE: This step is required to clear DTC C2780, cause the BCM to exit the manufacturing mode and to make sure there are no other concerns with a newly programmed BCM .
If the sensors are being trained due to the installation of a new BCM , clear any DTCs and carry out the BCM On-Demand Self Test.
Diagram shows the order in which to train as 1 left front 2 right front 3 right rear 4 left rear.
Hope this helps.
101,076
60,262
SVT_SMIT
