GEN 2 Torsen Bindind
Huck
Chicago Sw Burbs
Is anyone issuing binding from the torsen and major clunking from the transfer case in 4WD.
In gravel or dirt if I turn the wheel more then 15 degrees while in 4hi the torsen binds up and almost kills the engine. It “hops” like when the rear end is locked
Never had this issue on my gen1.
Making an appointment but figured I’d search around first.
Sharkus29
Kickin it in Canada!
Is anyone issuing binding from the torsen and major clunking from the transfer case in 2WD.
That doesn’t sound normal. It shouldn’t be binding like that on dirt or gravel I wouldn’t think. Definitely bring it in and see what they say
Booth9999
Idyllwild
I get slight binding in 4wheel high with lots of traction. Yours sounds more severe also 0 noise from the tcase for me. Good luck
jabroni619
In 2H the hubs aren't even locked so the torsen should not be playing a factor at all. If it is, I would look at the hubs being defective (being locked when they shouldn't be)
101,072
60,257
ladyraptor209
