To air down or to not air down?
Cooper Howe
Redmond WA
Should you air down your tires on dirt/gravel roads while off-roading?
If so what PSI should I run at with the stock tires and wheels?
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
it all depends on your comfort level and how rough the road is. i usually dont air down unless im in sand, but in rocky stuff dropping 8-10 psi would be a smoother ride
XLandrJP
Henderson, NV
Gravel and dirts roads, with wash boarding and ruts. Bone stock including tires.
30 PSI Good
25 PSI BAD! The compression and rebound of the tire is out of phase with the shocks frequently.
38 PSI BEST! Surprisingly.
Several 20mi runs on same trail.
I’ve been airing down for rock crawling, too...but I think I’m going to try 38PSI for that soon. I’m suspecting the added tire height will help with clearance and angles.
For reference, I would typically air down my JK to 14PSI on 37s. And that was superior in all driving modes. I’m surprised by the Raptor and lower PSI not working well. Counterintuitive.
Deleted member 12951
Guest
Never heard of airing down causing issues with shocks, new one there.
On my GEN1, I air down to 36 so the TPMS light doesn’t come on and if I do get a flat, I will know right away.
But I have aired down to 25 rear / 28 front when off-roading with no issues. Just be aware when taking corners fast so you don’t de-bead.
On my GEN2, I aired down to 27/30 and had no issues.
jzweedyk
Moab/Winter Travel/Summer Travel
I always air down off road and I have not noticed any problems with my shocks on my 19. I highly recommend it. Depending on the conditions and speed somewhere between 14 and 20 psi. I am lightly loaded and a Scab. On road 35/32.
adllewis42
Seattle
Like everyone else has said, it just depends on how rocky the road is, how long I'm going to be on it, and what level of comfort I'm looking for. If it's just a gravel road, I wont bother.
