Tire vibration?
Wassy
Tire vibration and suspension reverb
Does anyone else have a bumpy feeling on tires? A constant vibration and small bounce in tires. All speeds. Don't think it's a flat spot. May just be knobby tires or I don't know. If normal then normal but I'm thinking should be a tad smoother. It's not horrible but noticeable.
Also noticing when going over a certain small bumps the bounce echoes (reverberates) through steering wheel and continues a second or too. Similar to gen 1 but weird.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Kick the outside wall of your tire and tell me if you hear a thunk noise. Do you have vibrations when you're braking?
Jeff-Ohio
Cincinnati
I had to have both rear tires replaced on my 2017 Raptor when I received it. They were both so bad that the tire shop who was trying to road force balance them said there was no way they could be brought within spec. I found it interesting that both bad tires were on the rear where it is much harder to notice tire issues, especially on a truck. I would suggest having a tire shop try to road force balance all tires and then you will know for sure if that is the problem.
BajaFred
How low did they get your values
Jeff-Ohio
Cincinnati
I am not sure what you are asking. I had the tires tested about two weeks after I picked up the truck, it took the tire shop about 30 to 45 minutes to test all tires, and the dealership replaced the tires the same day that I showed evidence of the issue.
W
Wassy
So label says 38psi all around. I had 49/50. Dropped em and will see if that helps. Wife said she thought she was on ice skates. Lol
W
Wassy
I see a little improvement with the "bump". Almost seems like drivetrain related as feel it more in pedal as it happens and is also at low low speeds as well. Ride is more comfy with proper psi
