Tire problem after rotation
Discussion in 'Ford Raptor Maintenance Forum' started by OrangeTiger, Aug 2, 2014.
  1. OrangeTiger
    OrangeTiger Member
    7
    Aug 2, 2014
    Georgia
    Long time lurker here.
    I had my tires rotated for the first time and there was no abnormal wear before I did so. After a week or some I now have inner tire scalloping going on. Someone told me they were out of balance. Can I just rebalance, check alignment and get some more life out of the tires?
    Thanks
  2. RDFTS
    RDFTS aka Rick Supporting Member
    12,460
    8,613
    Nov 10, 2013
    Southwest Missouri
    I would post pictures
  3. OrangeTiger
    OrangeTiger Member
    7
    Aug 2, 2014
    Georgia
    Okay, when I get home and to a computer I'll upload some.
  4. OrangeTiger
    OrangeTiger Member
    7
    Aug 2, 2014
    Georgia
    [​IMG]
  5. dataustin
    dataustin FRF Addict
    2,294
    816
    May 3, 2011
    Tiger, same here... The first time I had this problem, Greg introduced me to 'road force balancing' which solved the problem. Most will say that the result is only as good as the technician. Well, the last time I had them balanced, the tech couldn't get one of the tires over 90.
    Just the other day when I had them rotated, there was a 'knocking' sound. Turns out the kid put three weights on the rim, which didn't rub on the front brake but did rub on the back.
    Bottom line, I'm right where you are today and trying decide where to take the truck next...
  6. RDFTS
    12,460
    8,613
    Nov 10, 2013
    Southwest Missouri
    What air pressure are the tires set at?
  7. OrangeTiger
    OrangeTiger Member
    7
    Aug 2, 2014
    Georgia
    Just checked them all, about 43-44 psi on all 4. OEM at KO's
  8. Secret Squirrel
    Secret Squirrel Full Access Member
    115
    56
    Jun 13, 2012
    Imperial, CA
    Check your alignment, specifically the toe adjustment. I had the same problem after the first tire rotation. The front tires started to get the same inner scalloping as before. I took it to the Ford Quicklane and they found the front tires were toe out past the acceptable specs. I just had it aligned recently, so I can't see any obvious results yet. Hope this helps.
  9. SonnyAK
    SonnyAK Full Access Member
    443
    429
    Mar 22, 2013
    Anchorage, AK
    How often are you all rotating your tires? I'm doing mine every 5k, since there seems to be some issues with going too long and getting wear in them from being at one point very long. So far they're doing good, but I'd be curious if the guys with issues are going pretty long between rotations or not??
  10. debate
    debate Full Access Member
    857
    90
    Apr 16, 2011
    NW Indiana
    How many miles are on that set of tires?
Share This Page
