Phil O
Sacramento, Ca
Hello guys,
looking at tires and wanted to see if anyone here had any real experience with either of the following tires on their Gen2 in the same size as the stock KO2’s.
Cooper STT Pro
Nitto Ridge Grappler
BFG KM3
I did recently put on 17” Venomrex 602’s which are 10lbs lighter than the stock wheel. I want to know how your experience has been with any of the above tires in the 35 size, performance on road as well as MPG changes and how long the tires lasted.
thanks!
Fshnrig
Snohomish, WA
Im in that boat too, but Im also looking at the Mickey Thompson Baja ATZ P3. Ran those on my previous truck and they were great tires.
Sgt Beavis
Colorado
Just a suggestion here. Go look at the reviews on the Falken WildPeak AT3W. For one, it has a better warranty that most 35” tires. I’ve got a set on my Wrangler and I’ve been very impressed. They didn’t hurt the ride at all and the offroad capabilities have been fantastic. I do a lot of crawling and have never gotten stuck. They are definitely better than K02s on wet pavement or snow.
The only thing I don’t know about them is their performance in Baja offroading scenarios, but I’m still planning to buy a set for my Raptor after the K02s wear out.
hedonist222
Dubai, Abu Dhabi, UAE
The Wildpeak look very very baja'ish
I like it
But I want something a little more aggressive - thats why I picked up 5 STT Pros today
Slightly off-topic , but should I pick up an additional pressure sensor for the spare stt pro and rotate it?
Looks like an OEM sensor is $40?
Phil O
Phil O
Sacramento, Ca
I like it
Nice! How much did you pay? Keep me updated once you get them on and if you can tell a difference in road noise and handling.... also MPG’s once you notice...
MattHamby598
Atlanta
I run ridge grapplers. They perform well. Downsides are 2, theyre heavy and stiff with the e load range.
hedonist222
Im in the UAE but I paid $253 per tire.
In addition to the aggressive posture, I went with the STT Pros because they weigh more or less the same as the stock KO2.
I'll let you know what I think because I drive about 15.000 to 18,000 miles a year.
So I'm familiar with road noise on long trips.
I'm also keen to see the difference in increased side-wall stiffness and pressure (45 vs 65).
I usually keep mine at 40-42 because I like agile handling.
My stock KO2 are at 28,000 miles now but never been rotated.
Phil O
Phil O
Sacramento, Ca
That’s awesome! I drive a lot as well. Hopefully you have some positive feedback on them and that might sway me towards getting a set finally!
hedonist222
Planned to have them installed this Friday :)
The drive back home from the dealer is 120 km.
The pro of having an E load index (versus c on stock) is that there'll be less stress on suspension when I tow my yamaha yxz 1000r. I guess?
Because the tires will now bear more of the weight?
hedonist222
Used the same decibel meter application to measure sound.
Before: 75-76
After: 77-78
The tire is rated to 65 psi.
I have them on 52 psi.
So very negligible.
There's a slight whirring noise but ill fairly certain it'll reduce as the sharp edges taper off.
Similar to off road motorcycle tires.
I noticed that it absorbs smaller bumps more than my ko2 but feels stiffer on larger/deeper road imperfections.
I notice nose dive also slightly reduced. Perhaps from either from the increased tire pressure (52 vs 42), or rigid sidewalls, or the stiffer knobbies.
Mileage has remained the same.
Phil O
Phil O
Sacramento, Ca
Before: 75-76
After: 77-78
So very negligible.
View attachment 139081 View attachment 139082 View attachment 139083
Looks good! How much better does it look, to you, in person? You happy with the switch so far?
hedonist222
Thank you.
Yes, very happy.
I actually thought they'd be more aggressive-looking in person.
I think because the side wall tread isn't as aggressive as other tires.
I'll have more feedback over the coming days as I use them on my regular drives.
hedonist222
I just remembered two things.
It doesn't start to rolls eagerly from a stop. Again, maybe because they're new tires and haven't molded to a street stance.
But I noticed that when they're rolling, without throttle, I don't feel rolling resistance.
Almost as if my ball bearings were just lubed.
But I suppose something like a discoverer 4s will be both smoother and have less rolling resistance.
Phil O
Phil O
Sacramento, Ca
That’s a good thing, right?
Fshnrig
Snohomish, WA
Im curious how the STT Pros handle in the rain. I like the aggressive looks but here in WA we get a lot of the liquid sunshine.
101,310
60,412
hugecrankfonz
