Hi,
I did a bunch of searching, but didn't find similar enough, so figured I'd try to start a thread. Was having some fun on a Raptor Run and then a whole bunch of codes came up:
C1165 - RR speed sensor circuit failure
C0151 - Lost comms with restraints control module (That's a new one for me)
U-0140 - Lost comms w body control module
C1299 - LR speed sensor signal fault
C1175 - LR speed sensor circuit failure
U0140-00 - Lost comms with body control module (Odd it was on there twice?)
O0217-00 - Engine coolant over-temperature condition (New for me, and temp gauge was right in the middle when this came on)
P193c-00 - Steering wheel angle signal
U0140 - Lost comms with body control module (cuz why not have it show up 3 times. LOL)
I had similar (but much fewer) codes with a right rear speed sensor, which I replaced before the raptor run. I also had a bad factory 3rd brake light, which I changed out to the GJ, and there's no water/condensation or other issues with it.
When it happened we pulled over, and none of the wiring looked like it got mangled by a rock or anything, and once home, I traced all the lines and double checked, all the lines look good. I checked the connector above the e-brake and it seems fully seated, I reseated all the connectors I could under the dash on the passenger side.
Any other suggestions on where to look and what to test?
Also, where do you guys unplug the rear speed sensors to test AC voltage while spinning the wheels? The spot they plug in to the factory harness is a fracking PIA to get to and to undo those plugs. lol Is there some other connector I missed? or do you go all the way into the engine bay somewhere?
Thanks in advance!
And pic for attention of the some fun during the Raptor Run!
Thanks in advance!
