Tepui Tent
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by Red GSXR, May 20, 2020.
  1. Red GSXR
    Red GSXR Member
    29
    10
    Jan 27, 2020
    Nunyabiz
    Has anybody mounted a tepui kukenam 4 tent on their bed? I am thinking about yakima outpost and retrax pro xr cover.
    I am worried about the weight allowance of the yakima adapters and also the tent hanging over tail gate.
    https://tepui.com/products/ruggedized-series-kukenam-4
    The specs show
    Size (Closed) 72" x 48" x 12" (W x L x H)
    Thanks in advance.
  2. 17Fiddy
    17Fiddy Member
    3
    Apr 26, 2020
    San Antonio Texas
    I’ve got the xl smittybilt tent. It hangs past the tailgate a bit. Hasn’t bothered us any.
  3. cjs
    cjs Member
    3
    Apr 12, 2019
    Reno, NV
    I have the autana 4 with annex mounted on my truck, which is the same size as the kukenam. Yeah it hangs over a little bit, but we usually don't notice. I did get the non-ruggedized version to make it a little lighter to take on and off. It's been solid mounted on frontrunner load bars on some rails I added to my diamondback cover.
    Red GSXR, amREADY and Ciqir like this.
  4. amREADY
    amREADY Full Access Member
    126
    60
    Aug 24, 2019
    Victoria, BC
    Great setup. That was the way I was going to go, but ended up going Retrax for easier access to the bed. Trade off is less strong, less watertight, and encroaches on useable space below. It was a tough decision.
  5. amREADY
    126
    60
    Aug 24, 2019
    Victoria, BC
    I went with an Autana 3 ruggedized and the retrax/Yak overhaul hd adjustable. In order to reduce torque on the rack attachment, I run it at it's lowest height. Not sure how much difference it makes, but has to make a little bit. As a result, I am running at or just above the offroad capacity of those racks/adapters/rails. It feels rock solid and even on a rough trail there is zero play or movement in the setup.
    As far as the 4 sticking out, it is a consideration for sure. If you are mounting it low like that, you'll lose the ability to stake out one of the windows with the spring poles. I am right on the limit of clearance for mine at 18".
    [​IMG]
    [​IMG]
    [​IMG]
    Red GSXR likes this.
Share This Page
