Tampa, Florida: ADD Stealth Fighter Winch Bumper Line-X’d
MAMiller44
Tampa, FL
Located in Tampa, FL. If I go a few months without being able to sell locally then maybe I’ll consider dealing with freight.
Bumper does include the fog light covers that say Stealth Fighter (I just don’t rock them). Includes all hardware and the ADD frame reinforcement brackets which are needed for a winch. The bumper new will run you $2,415 but you have to get the reinforcement brackets as well for $184. Skid plate is cut in two pieces (if you don’t do it with this bumper you have to remove the whole bumper + winch to change oil). I am NOT selling the winch, fairlead, or fogs. Coating is actual Line-X which was around $350. This is 100% bolt on in case you weren’t already aware of that, it is not a frame cut bumper.
Also selling the Rigid Radiance 40” Curved bar with Amber backlighting. Looks like current pricing is around $1,150 for those. You can run the main lights on the bar off a single 15amp aux 1 or 2 as long as you are connecting the amber backlighting elsewhere, which you should anyways so it stays on as a running light .
Bumper + Frame Reinforcement Brackets: $2,000
Rigid Radiance Bar: $700
Combo Deal for Both: $2,500
All has treated me well! I’ve just decided to go more aggressive with a frame cut front bumper and a custom fabbed high clearance rear bumper that will also house the winch hidden behind it. Haven’t removed from the truck yet but will probably do so next weekend once SVC ships the new front bumper.
MAMiller44
MAMiller44
Tampa, FL
Have you been able to sell this yet? I am located in Tampa and might be interested.
Not yet, I actually didn’t get around to removing it until yesterday. Taking a break while the steel-it dries on the frame cuts as I type before putting the SVC Mojave on. I’ll PM you.
