Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Tailgate not dropping with remote
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by Fury Road, Mar 16, 2019 at 9:39 PM.
  1. Fury Road
    Fury Road Member
    40
    16
    Dec 7, 2018
    New Jersey
    Worked fine at dealership a few weeks ago, but then stopped working. Thought it might have been colder temps but it’s been warming up. Has factory bed liner and tonneau cover. Anyone else experienced this recently?
  2. Johnkn
    Johnkn Full Access Member
    396
    227
    Nov 29, 2018
    LaPlata, MD
    What happens when you move the cover out of the way so it's not touching the gate?
  3. Offsetz33
    Offsetz33 Full Access Member
    67
    27
    Oct 28, 2016
    Sometimes mine hangs up on the bed cover. Might need a slight adjustment
  4. Jon D
    Jon D Member
    5
    Jan 27, 2019
    Florida
    Mine used to hang on my 502a lariat due to the bed liner being sprayed a bit too thick.
  5. Fury Road
    Fury Road Member
    40
    16
    Dec 7, 2018
    New Jersey
    Thanks guys, seems to be related to the cover. Works fine when I pull it back.
  6. priest880
    priest880 Member
    12
    Sep 2, 2017
    Only happens when the truck is at an angle not allowing the tail gate to fall properly
  7. df4801
    df4801 Full Access Member
    781
    585
    Nov 9, 2016
    I think it's normal.
    Try it when you are parked up hill.
  8. pierceography
    pierceography Full Access Member
    646
    367
    Jan 4, 2018
    Mine did this after I installed the tonneau cover (MX4). I adjusted the cover to reduce the overlap until the tailgate would release without any manual pressure.
    There is less weather sealing making contact with the tailgate, but I also don't need to pull the tailgate open. So far, water intrusion hasn't been a major issue.
Share This Page
