  1. BucksRunner
    BucksRunner Member
    29
    14
    Jul 26, 2019
    Perkasie, PA
    A couple of weeks ago I pulled the trigger and purchased a new Sync3 system from ebay. It took nearly two weeks from when I purchased it and when all the parts arrived. The APIM and screen came direct from China while the USB ports and cable came from NY.
    I installed the unit this morning and after all is said and done it was completely worth the money. Not only do I now have Android Auto, which is the primary reason for the swap, but the radio IMO is exponentially easier/friendlier to use.
    In regards to the swap, I watched a video on how to the install on a normal F150 () and quickly realized that wasn't going to work. I found a link in a sub forum on FRF that detailed the dismantling of the center stack -
    Just to note, you don't need to disassemble the shifter linkage (starting at the 3 min mark in the video above), in my case there was more than enough slack in the connected wiring harnesses to slide the center console back to get a ratchet at the necessary screws. Also, there was no need to undo the two bolts under the cluster bezel (8:20 mark in video) to remove the side vent stack.
    My "kit" also came with an ELS27 OBD2 connector so I was able to use forscan to change the default FORD splash screen to the Raptor splash screen. It required only changing one string in the APIM AS BUILT module. Instructions were here -
    If you have any further questions let me know.
    kosti365 likes this.
  2. SupercrossBMX
    SupercrossBMX Full Access Member
    78
    14
    Jun 16, 2019
    Hi desert, Ca
    So rad! Wish I could do that in my 2011 that has Sync 1
  3. The Car Stereo Company
    The Car Stereo Company aka nosbusa Supporting Vendor
    42
    26,113
    9,292
    Jul 8, 2012
    here, on frf
    ha. i made that middle video years ago. glad its still useful
  4. IamRonBurgandy
    IamRonBurgandy Member
    3
    Aug 23, 2020
    Washington
    I just installed the Sync 3 upgrade and the seats no longer heat/cool and there are no Raptor apps. Were you able to get those working?
Share This Page
