Sync 3 Radio Presets
David Goodman
Va Beach
There are three different memory groups but when switching stations using the steering wheel the only ones available is the one of three it is currently in. Is there a way to be able to scroll through all 18 stations without having to use the touch screen to switch station memory group??
In my other cars (non Ford) it’s easy to scroll through all memory stations programmed but Fords seems antiquated and labor intensive
GCATX
King Dingaling
Central Texas
No, and it's very annoying.
Donmatteo
Santa Clarita / Coronado
What version of sync are you on? I have 4 (but up to 6 are available) preset lines and can scroll between radio, xm etc without hitting the source and I can scroll from the wheel through all 24 presets. oddly enough, @smurfslayer didnt have this option with his 17 running 3.426E75242-3F3D-4B0A-A83F-65BCC7365E64.jpeg 6D5EEE31-1791-42A8-96A2-072D67A35B4F.jpeg4A5BB35F-4382-4E94-9551-01F7B85A2EDB.jpeg2F8E3F44-FF99-43A0-960B-0F3E1DA6A7E8.jpeg
I did not do the firmware update, I just updated the code itself. did you do the firmware update?
to the op question; if you look at the F150 manual, you’re supposed to be able to summon specific presets on sirius or fm by voice, but, I’ve never been able to get this to actually work.
Donmatteo
Me? No. Mine was from the factory like this.
David Goodman
David Goodman
Va Beach
I tried and it said I was using the most current version and truck is new
I suspect the additional presets are part of the firmware update, but you only need the f/w update if you’re lower than (?) 3.2 and even so, it was optional. I opted not to do it. not a deal breaker for me, I got the auto-updating DST :)
GCATX
King Dingaling
Central Texas
I see you previously had a 2018, was it the same?
David Goodman
David Goodman
Va Beach
Just checked and it’s Sync3 2.3 on my 2018 delivered Apr 2018 (built late Dec 2017) Guess I need to update. Anyone have the best way and what to do?
