Sync 3 Fuel Prices?
Flash1034
N/W Montana
New loaded 2019 Raptor. Sync 3 says I’m subscribed to Sirius Xm Fuel Prices but when I push the button, it spins an electronic circle and does nothing. What’s normal operation?
thanks
do other XM / satellite functions work - weather, traffic?
sounds xm related.
jzweedyk
Moab/Winter Travel/Summer Travel
Take it back to the dealer, they can reset it. I had the same problem when I got my 19, and I spent over an hour on the phone with Sirrus/XM. Nothing worked. I took it to the dealer and they did a master reset (I guess) and it fixed it. You can try a master reset by yourself, just know it will wipe any information you have input, but in my case it fixed the problem.
jzweedyk
I think it is in the Sync menu under settings. According to the internet, the truck must be running and you need to unpair your phone first. Then do a master reset. All information will be lost and it will go back to factory settings. The other option is just take it to the dealer, it should be covered under you warranty.
EricM
OHIO
I use Android Auto in Sync 3 to find gas. If the nav is set to a destination, all you have to do is hit the voice button (which will brings up Google instead of Sync) and say "cheapest gas". It'll look along your route and show the cheapest stations and how many minutes detour off your route to each station.
Flash1034
Flash1034
N/W Montana
I have an iPhone but I’m not sure that matters. I still can’t get it to work. Dealer stop I guess.
