Switch Pro Set Up
Nex
RIP CoronaRaptor
Washington State
I know that a number of people are running Switch Pros either due to the amount of lights they have or for their strobe option.
My question is for those that use the strobe set up. What lights do you have sep up for it and where do you have them mounted?
Video clips would be great. Thanks.
Nex
Nex
RIP CoronaRaptor
Washington State
Does anyone make/build a switchpro relay and fuse set up? Or is everyone just wiring straight to the module.
Like this one for a Taco
jm77
USA
I’ve installed a couple SPOD and a switch pros, I still don’t see the appeal in the switch pros aside from there seems to be more vehicle specific mounts available. Having to mount the fuse box and terminals in addition to the switch pros seems to make it a messy install. The SPOD is self contained and makes for a clean install.
FYI, I’m pretty sure that install method is not recommended by switch pros. I think they advise to use but end connectors to connect the leads instead of a fuse block. Even though most people do it as you pictured.
Nex
Nex
RIP CoronaRaptor
Washington State
Ok. Getting ready to install all of these lights and have a game plan set.
Question I have is has anyone found a good ignition circuit to tap into near the battery? Also looking for a high beam circuit to tap.
I'll tag @FordTechOne just in case.
Tomorrow will be wiring...
Nex
Nex
RIP CoronaRaptor
Washington State
Tommysyko
Bay Area, CA
Following. Doing the same on my Gen 1. Did you go with the direct wire to swtichpro install or the fuse box in between?
Tommysyko
Bay Area, CA
Copy that. But are you doing the direct swithpro wiring to your lights or are you getting the terminal box in between that one (like the Toyota guys).
Nex
Nex
RIP CoronaRaptor
Washington State
