Sway bar disconnected
Peterb
vancouver
after off roading I noticed my sway bar is disconnected at the lca, it’s come loose before and been tightened now it’s off, i’m wondering if it should just be removed and forget it
CoronaRaptor
CANADA
Get new end links and use some locktight on the nuts, problem solved. Cheap fix. Sway bar is there for a reason, you paid for it, use it!
Simplejack
dallas tx
P
Peterb
vancouver
thanks ryan, good opinion article, I drove a day and noticed no difference then saw the broken link, I have kings which are stiffer than stock which in theory lessens the sway bar effect, again theory is front sway reduces oversteer rear sway reduces oversteer (we have no rear sway) sways in general band aid soft springs, I drive slow on the street anyway removing the sway might just exclude the headache if the link keeps breaking
P
Peterb
vancouver
