GEN 2 Swapping your live valve shocks? Check the solenoids first
RaptorSam
United States
Ordered some rebuilt live valve shocks for my 2019 through a reputable shock exchange program (out of state). Sent the truck into my local shop to get the front shocks swapped out and got a call a few hours later that one of the solenoids had seized onto the valve of my old shock. This manifested as a free spinning solenoid around the valve when trying to remove it and required ordering a new solenoid for around $350.
I had set aside the following day to swap out the rear shocks myself. The job was cut short when I learned that both of the rear solenoids had also seized up and likely cannot be removed without destroying the solenoids, or at the very least splitting the nuts, which as far as I can tell are only available by purchasing the entire solenoid.
The only information I've found online addressing this issue is this video which talks about the problem and how to get the solenoid off.
I'm assuming there is very little discussion about this as most gen 2 owners likely rebuilt/replaced shocks after hitting 50k miles a few years ago, before corrosion set in. I bought my Raptor last year with 46k miles, which is a long time for those aluminum solenoids to be untouched in God knows what driving and storage conditions. I imagine we'll start seeing this issue more as gen 2 owners go to swap their shocks out again, or for the first time at 100k+.
I figured it was worth starting a thread on this issue since there is virtually no information online about this solenoid issue with live valve Fox shocks on Raptors.
Knowing about this before ordering your shocks is important, especially if doing a shock exchange program, because you're looking at potentially $1,400 in new solenoids and getting those shipped to you before swapping the shocks out. That changes the value of a swap entirely. I'm considering sending back the rebuilt rear shocks and just purchasing the whole OEM shock assembly which includes new solenoids.
Major PITA and a disappointment thinking I could get away with a $1,200 shock rebuild.
Anyone else here experience this issue?
Minnesota
Getting my first set of exchange shocks installed today and had the same experience…. I’m at 68k miles. Fortunately only one of them was seized.
Spooder
Key Largo FL
Any issue with routine maintenance: remove/clean/lube the solenoids? Seems perhaps easy compared to the consequence. And no need for recal if the solenoids aren't swapped around? Anybody have the torque for the retaining nut?
D Curley
Sacramento, CA
Also used a reputable exchange company and a reputable tire shop in town. RF have them a tough time and they damaged the shock in the process. Waiting to hear back from the exchange company on what it’s going to cost.
RetiredRaptor
North Carolina
Thank you for posting this message. I just bought my first Raptor. It's a 2019 with 104,000 miles. As far as I know the shocks have never been rebuilt or replaced. I'm going to set up an appointment to get them rebuilt ASAP. Christianmotox mentioned "checking the caps to see if they are stuck". What caps and how do you check them?
nyzgreatst
DE
Were you able to figure out where to buy the solenoids? Had the same issue. Rears finally got swapped but the fronts are not coming out at all. I have to replace them both but not sure where to order.
thatJeepguy
GA
Aaaaand thats why I undercoat my truck every fall , including the shocks and leafs….
welndmn
Concord
I think it's pretty depended on where you live as well. Out here in California I have done 20 ish shocks, none of them were remotely corroded or had any signs of it.
101,310
60,412
hugecrankfonz
