SVC Gen 3 Adjustable Bump System (ABS) Install – Anyone Have Detailed Instructions / Tips?
Deputy Steel
Deputy Steel
Supporting Member Marine Corps
SoCal
ALSO I’m assuming I’ll have to buy a special tool to torque the blue rings onto here? That or hope that my old Fox 2.5 coilover wrenches fit!
RoNiN Raptor
Army Supporting Member
Arizona
I’ll snap some pics of my bump strike plates tomorrow, yes your going to route the brake lines and wires along that plate. Again I’ll snap those pics for reference.
I would just head to the hardware store and grab some grade 8 hardware so you don’t have to wait.
You’ll need a spanner wrench, I bought a set from Amazon for like $15, then I have a bunch of different sizes. I’ll snap those pics as well tomorrow.
You’re doing fine don’t worry about asking questions, it’s important to get these in correctly. You’ll be very happy with them once they’re installed.
SVC makes great products but their instructions aren’t nearly as good as the products unfortunately. Maybe this is their way of bringing the community together.
Deputy Steel
Deputy Steel
SoCal
Rgr that, I quit for the night. Going to attack it again tomorrow. I appreciate you checking out that stuff I asked about, just a bit of confusion if my goal is to make the brackets touch or just get them "tight" and call it good. I might be an idiot and tightened one side too tight then went at the other causing the snap. I'll order those wrenches tonight so I can use them tomorrow. Again I really appreciate your assistance, and I look forward to those pics, and maybe getting this completed tomorrow!
Interesting enough, during my research I found that the top trailing arm bolts are supposed to just be snugged up, and then do the final torque (173 lb.ft) after its resting on its wheels!
I've been attempting to take pics as I go so I can do a "mediocore" install insturctions write up in case it might help others in the future
Deputy Steel
Deputy Steel
SoCal
It looks like you & SeasickLI have the top part of the tab still on, so maybe need to cut the bottom part of it off IMG_1046.jpegIMG_1045.jpeg
RoNiN Raptor
Arizona
I cut that tab off on one side and not the other. I figured it didn’t interfere so I didn’t add the work. I have a small gap between the lower bracket and top strike plate.
Deputy Steel
Deputy Steel
SoCal
RoNiN Raptor
Arizona
Hell yeah man glad it worked out for you! Take it out and put it through its paces those bump stops are a major upgrade, really elevates the stock suspension for sure.
Deputy Steel
Deputy Steel
SoCal
I went a bit crazy trying different variations for the brake lines/wire set up. Here is where I ended up at, actually reused the OEM wire routing and I’m pretty happy with how it ended up! Again will need to check contact patches, but for now it looks like it will be all good!
Only thing I’d like to add is maybe a little tack weld to guarantee the brake line brackets stay in place, but I’ll either have to learn how to weld or find someone who can do it quick.
Lemme know what you think!
101,297
60,427
SVT4DGUY
