Just picked up the SVC Gen 3 ABS kit for my 2022 37 Package Raptor, and I'm getting ready to install it. SVC only provides the install video on their website, and it moves through some parts of the install pretty quickly. I also emailed SVC and confirmed they don't have PDF instructions. Has anyone here installed the current version of the SVC Gen 3 kit themselves? Mainly looking for any tips/tricks, torque specs, or anything you wish you knew before starting. I also found RPG's Gen 3 frame support/air bump installation PDF, which seems helpful to reference, but obviously I don't want to assume their installation procedure or torque specs carry over to the SVC hardware.
Basically, with the links I've provided below, is this enough information to get the job done without running into anything unexpected?
One other thing I noticed, in SVC's install video they show cutting/grinding some factory brackets/tabs off the axle, but the current kit is advertised as "100% bolt on." Is that cutting still required with the current Gen 3 kit, or is that portion of the video from an older version/design? I also heard the King bumps can be set up differently for off-road use vs. max-payload/towing settings. Is this something I need to reach out to King about for setup instructions?
Any help or pictures from your install would greatly be appreciated!
SVC Kit (King 2.5, 37 Wheel Size)
SVC Install Video
Gen3 REAR Stage 2 Frame Support Installation Guide
Video I found online of an install
SVC Install Video
