Svc 1.5 uca
svc
Worldwide
SVC Performance Series 1.5” UCA’s (Upper Control Arms)
For those of you who haven't had a chance to check out the website or see pictures of the arms here it is!
Two Piece Functional Design
8740 Aircraft ¾” 12 Point Flange Head Bolts
Larger 7/8ths FK Rod Ends vs 3/4 Rod Ends as found on some other UCA’s
1.5” FK Spherical Bearing
Grade 8 Chassis Hardware
CAD Designed
SVC Laser Cut and Bent Box Radiussed Construction
Fully Adjustable Caster and Camber
Yes, you see them correctly, the SVC Performance Series 1.5” UCA is developed from a race inspired two piece construction to make life with your SVT Raptor even more satisfying. The concept behind this two-piece design was inspired by one of our favorite class 10 race-cars sitting inside the shop. There are multiple advantages to going with an SVC two-piece UCA over the others more conventional designs. First and foremost is the ease of fine-tuning camber and caster to your UCA’s. Simply unbolt the center bolt, and then unbolt the secondary bolt that attaches to the arm to the bearing cup, and start to spin away. Each side will allow you to adjust the length of the arm at the heim without having the headache of unbolting the shock, and removing the arms each time you adjust. This can save hours out of your day, and guarantee that no matter how much you raise or lower trucks perch settings, your trucks alignment will always have the ability to be true and correct.
Another added benefit to having this type of system is when you are installing or adjusting the preload on your shocks. Simply unbolt the secondary bolt, and swing the arm to the side allowing you more room to manipulate the spring perch collar.
The SVC Performance Series 1.5” UCA is designed using the latest in modern CAD technology and is actually a complex arm to build compared to most of the others on the market. A unique feature with our arm is the bent, radiussed boxed section on the front side of the arm. Getting the correct bearing cup angle is crucial to a well-built part. But also making sure the surface the bearing cup is welded too is flat and tight as possible to ensure the UCA’s integrity. Because we take the time to radius and bend our arm flush, we have zero gaps to weld on the bearing cup unlike some other designs. This leads to a better weld surface with a race-truck like appearance.
During the development process, we also toyed with making custom center pins to fit the taper of the factory knuckle. The problem is, over the years we have seen numerous center pins break and fail from multiple manufactures, and that’s something we don’t want any part of. We ended up finding our inspiration from the many Trophy Trucks, Class 1 and Class 10 cars sitting at the shop. One common theme was they all used a ¾” 12 point 8740 Aircraft bolt to attach the UCA to the upright, and never a tapered 5/8th or 9/16ths center pin. We figured, if its strong enough for a $500,000 race truck, why should you have to settle for anything less. Simply run a ¾” step bit through the bottom of your knuckle, and hone it out with a normal ¾” carbide bit, and you too can run a full-blown trophy truck style bolt. Trust us when we tell you this makes your life much easier. You no longer will have to set tapers. You will no longer have to wait for custom center pins to be shipped from the manufacturer if you break one or degrades over time, and you will never have to worry about snapping one in half.
SVC 1.5" UCA
Arms are standard in either all satin black or satin black with SVC Yellow Tube. For $50.00 more, Blue, Red, Orange, White, Silver, Gray or Red Candy available to color match your Raptor paint.
If you have any questions please ask!
-SVC
svc
svc
Worldwide
Is there a limit on what amount backspace is allowed with these arms?
Ironside,
Just like the other 1.5" bearing cup arms on the market you typically want to stay with about 4.5" of backspacing.
Depending on the tire width and stock wheel, you can run a small 1/4" or so small spacer to get the clearance you need. Or just do what everyone else does and get Methods J/K.
Hope this helps answer your question
Jarrett
---------- Post added at 08:27 PM ---------- Previous post was at 08:17 PM ----------
What is it made of?
Arms are made from a combo of mild steel and 4130. The portion that the secondary bolt goes through is the 4130 section.
Thanks for the question
Jarrett
svc
svc
Worldwide
Purdy... Now you just need to add Tan to the color options to Go with the Terrain
I actually think I found a powder color that is dam close to the Tan. If you wanna be the test case for it, then I will make them.
Jarrett
ironside
All over
Ironside,
Jarrett
Jarrett
Thanks for the info I will prolly just stick with the 1.0 inch bearing cup ones as I already have bought after market wheels and they aren't that far offset and don't wanna go through the hassle of getting different wheels.
svc
svc
Worldwide
I have the ford beadlocks will they work with your uca's
We will be offering a 1/4 inch spacer for the front, this does not effect reliability or the studs because the spacers are so small and just enough to keep the wheels from rubbing! The stance difference is nearly unnoticable
-Jeff
