GEN 1 Suspension upgrades
coachhomer
All, I am about to order the following parts to upgrade my suspension...
Fox 3.0 front and rear shocks
Deaver +3 HD rear springs
Icon bump stop
Icon UCA
ADD tie rods
I have 2 questions:
1. How should I stage the install in the back to maximize my productivity? In what order should I install the parts?
2. Any recommendations or suggestions before I tackle this project?
Many thanks!
C
Pacific Wheel
Reno, NV
If you're doing one part at a time I'd probably go bump stops first to avoid frame damage. From there you could piece it together as you see fit. Me personally one at a time
bumps
deavers
shocks
tie rods
uca
C
coachhomer
You doing yourself, or having done ? BTW the truck is going to rip with that combo.
Thanks. I poorly communicated. I will have all of the parts. What I am wondering is when I do the back, what order should I work on it to make the job as easy as possible? Should I install the new springs and then the bump stop as the axle supported and then finish with the shocks or is there a better order of operation?
Thanks!
C
