Southern Car Parts has Huge Upgrades at the Best Prices Possible!
Here are some of our Best Selling Suspension Upgrades:
2017 FORD RAPTOR CONTROL SWAY-A-WAY 3IN REAR BYPASS SHOCK KIT
Website Link: https://www.southerncarparts.com/2017-ford-raptor-control-sway-a-way-3in-rear-bypass-shock-kit.html
The 2017 Ford Raptor Control Sway-A-Way 3in Rear Bypass Shock Kit has giant 3.0" diameter triple bypass shocks that feature all the same race-winning engineering and components that have 20+ years of testing, into a specifically designed kit that will bolt directly into your Raptor. This kit offers ultimate off-road performance without sacrificing any on-road comfort or handling. These rear shocks are 100% designed and built in the USA that features the bright zinc plated steel cylinder bodies and CNC machined aluminum components. This package is designed as a direct fit application and requires no modifications to the vehicle.
APPLICATION: 2017 FORD F-150 RAPTOR
2017-2018 FORD RAPTOR READYLIFT OFF ROAD LIFT KIT WITH SST3000 SHOCKS
Website: https://www.southerncarparts.com/2017-2018-ford-raptor-readylift-off-road-lift-kit.html
The 2017-2018 Ford Raptor ReadyLift Off Road Lift Kit is one of the most aggressive on the market. With a 7" of front lift, 4" of rear lift, and coming with SST3000 Shocks which will give you superior control for large-diameter tires, independent rebound, and compression tuning, and reducing harshness, this Lift Kit will allow you to go where another Raptor simply cannot.
The height of lift you get with this kit will allow an upgrade to 37" Tires with only minor trimming.
2017-2018 FORD RAPTOR READYLIFT LEVELING KIT
Website Link: https://www.southerncarparts.com/2017-2018-ford-raptor-readylift-leveling-kit.html
The 2017-2018 Ford Raptor ReadyLIFT Leveling Kit provides 2.25″ of front lift and features a design developed to provide clearance between the Raptor's strut and aluminum knuckle. Our offset design allows the suspension to cycle without interference. Without this offset design, the strut and knuckle will contact at full suspension droop.
Made in the U.S.A. – Using the highest grade material available – CNC Machined 6061-T6 Billet Aluminum.
2017-2018 FORD RAPTOR READYLIFT SST LIFT KIT
Website Link: https://www.southerncarparts.com/2017-2018-ford-raptor-readylift-sst-lift-kit.html
The 2017-2018 Ford Raptor ReadyLIFT SST Lift Kit has been developed to give Raptor owners a packaged front/rear lift option that lifts the front of the vehicle 3.5'' with 1.75'' in the rear. The CNC-machined billet aerospace-grade Aluminum lift spacers feature a unique offset bolt design engineered to position the strut into the stock position. This translates into proper suspension clearance and guarantees your truck will ride like it was stock.
2017 FORD RAPTOR PRO-LIFT KIT
Website Link: https://www.southerncarparts.com/2017-ford-raptor-pro-lift-kit.html
The 2017 Ford Raptor Pro-Lift Kit allows for full range of suspension travel without additional stress on bushings and ball-joints. The Lift Kit raises the front suspension 2.5 inches to give your Raptor a level stance, with more comfortable bump travel and off-road performance.
This Pro-Lift Kit is manufactured using winning off-road race spring technology, in the USA.
