Suspension squeak
tltoronto
toronto ontario canada
either its spring rub or your lower shock mount spray some lube on either one at a time and do a compression check. I was wondering wether it was even your front, and maybe your leafs.
6point2raptor
6point2raptor
Alabama
I think it’s one of my control arms I keep my back leaf springs greased up or they’ll make noises when going off-road
tltoronto
OOh I don't know. The control arm bushings are solid rubber, unless the control arm bolt is loose to allow the pivot sleeve to creak in the frame, I don't know how it could make that noise. If you get another buddy to rock the truck, you can grab certain points and maybe feel the creak.
Mikehill33
Silver Spring, MD
I just fixed this same issue. I used lithium grease in all the shock bushings. I used Red n Tacky to grease all other bushings on the bed, hitch area, and any other place I could imagine squeaks. Problem solved!
Sent from my SM-G973U using Tapatalk
