Super Duty Trans Cooler
Stricken
Vail, Az
I happened to have a trans cooler from a 7.3 Super Duty, and noticed that it is just about a drop in replacement for our trucks. You just need a few adapters. One of the mounting holes even lines up perfectly with a hood release mounting hole. This is a very common mod for the Lightning guys, and I'm wondering why you don't see it on Raptors?
I see that the SD cooler runs 3/8 vs 1/2 lines, but I'm figure the extra cooling capacity and lower internal restriction should at the very least offset that.
I went ahead and threw it in while I was installing my Whipple, so we'll see how my trans temps look in AZ this summer.
S
Stricken
Vail, Az
Ahhh! I had this one in hand. It looks like it has a few more rows, but that one does look even easier to drop in.
98rangerdave
High Desert 92392
Most guys just upgrade to the saudi spec cooler, as it is an actual direct drop in with the correct size lines and fittings. DL3V-7A095-B
I just ordered this from an eBay seller, wanted to go with forged off-road but the price on eBay was $98 and shipped free. Too hard to beat.
pastorwug
Santa Maria, CA
I like this idea, thatnks, we tow an Airstream a lot so I could use a bigger Tranny cooler.
98rangerdave
High Desert 92392
We tow a Flagstaff popup trailer a handful of times per year (dry weight 2,800 pounds) and since I’ve installed the larger cooler the trans temps are 10-12 degrees cooler on the freeway. Not a huge difference but it’s nice to see it’s working.
