Subwoofer In Jack Area
themarcg
Here to ask if the Skar sub would even fit let alone which would sound better. I have a Milwaukee pack out in my bed so I’ll move my jack. I’m not looking to be a kid again but the lack of bass after you go to 24 on the volume is underwhelming. Just also looking to hit those lower lows and more punch. I listen to a lot of heavy rock, punk rock, and every now and then I’ll get ghetto with some 2000s hip hop from 50 cent. Just looking to fill that void from lows and want some opinions. Not looking to get a huge box under my seats either. I’m coming from 2000 watts in my jeep JLU so this sound system is not bad by any means just want a tad bit more bass.IMG_7484.pngIMG_7487.png
Kauai, Hawaii
This is the sub I installed in my 2021 (it was behind the driver rear seat, also needed to cut the carpet):
Use any amp to your liking, and I used this to pull signal:
I found write ups online about this sub, not sure if it was this Forum or the F150 Form
The Car Stereo Company
here, on frf
it will be a tight fit and you will have to get the box as low as possible, but the issue is the ability to fold the seat up. the seat pivots and the back cushion moves. if you can get it back there, you will definitely lose the ability to lift the seat bottom on that side.
themarcg
themarcg
Did you
Is it any different behind the 24 model? Also can you fold your seat up?
Kauai, Hawaii
Did you
Driver side rear seat could fold up, although it did get harder to latch it in the up position.
The 24 model's amplifier moved to behind the jack on the passenger side and subwoofer moved to behind the driver, so there is more room behind the driver's side to install an aftermarket speaker and amp.
Also forgot you will need one of these when you remove the factor subwoofer:
Here it is post #49 and Post #55 (although different gen, idea and fitment still the same).
msharpe08
North Carolina
The area behind the seats on the 24 is slightly different compared to a 21-23. I got my box and amp for my 24 from Sounds Good Stereo. Easy to install and the seats close. It’s a tight fit, but everything still works. The two 6.5 subs are not breaking any records, but they give a decent amount of bass. Especially compared to stock. Sound treatment on the doors also made a big difference for the stock door speakers.
