stumbling engine
Discussion in 'Northeast' started by appetites1, Jul 10, 2017.
  1. appetites1
    appetites1 Full Access Member
    488
    268
    Oct 30, 2011
    Belleview, Florida
    we moved fro the northeast to florida
    each time we fuel our 2010 scab (6.2) the engine stumbles badly on the restart
    this only happens after refueling
    any thoughts/suggestions
  2. SZDZMTR
    SZDZMTR FRF Addict
    2,257
    1,960
    Sep 19, 2016
    Sewell, NJ
    Try changing the Gas station. Are you putting premium or regular?
  3. AndysLog
    AndysLog FRF Addict
    1,124
    514
    Jan 12, 2017
    Moro IL
    what do you mean stumbles?
    hard to start? takes 4-5 seconds? multiple cranks?
    what it sounds like you are describing like the battery is disconnected and re connected.
  4. appetites1
    488
    268
    Oct 30, 2011
    Belleview, Florida
    just runs rough for a few seconds and then clears
    have tried different grades of fuel at many different stations
    we have owned it since new with 88k on it and this is a new development
  5. BBQPorkins
    BBQPorkins Full Access Member
    285
    202
    Nov 23, 2014
    NY
    Mine just started the same thing. I was going to check the maf sensor and maybe clean the air filter
  6. appetites1
    488
    268
    Oct 30, 2011
    Belleview, Florida
    yeah, we did that
    maybe part of emission /vapor recovery system??
  7. AndysLog
    AndysLog FRF Addict
    1,124
    514
    Jan 12, 2017
    Moro IL
    air/fuel/spark/timing
  8. BIGt0007
    BIGt0007 FRF Addict
    1,541
    815
    Jan 16, 2012
    CT
    what about the fuse relocation fix???
  9. CoronaRaptor
    CoronaRaptor FRF Addict
    11,544
    2,642
    Dec 17, 2012
    It's the canister purge valve! Cheap part and easy to replace! Had it done to mine! Located on the intake. It causes the engine to flood, gas vapours are being dumped into the engine when refuelling. Will eventually throw codes for the cats.
    Jimster58 and Backinblack like this.
  10. Mitchell007
    Mitchell007 Member
    10
    Dec 7, 2015
    I have had the same thing but it seems to happen most when I am very low on fuel. It’s been happening for a long time with no issues that I can tell from it.
    Did you try the canister purge valve replace that coronaraptor suggested?
Share This Page
