GEN 1 Stripped spark plug threads
gn1raptor
NY
Having a bit of a problem, upon removal of the first spark plug on the passenger low side ( right near shock tower) the threads appeared to be pretty chewed up, i cannot thread a new plug in all the way. Would a Save a thread type kit hold up over time if i go ahead and repair the threads with the insert? i don't think chasing the threads will work as they are in pretty rough shape. the tools on some of these repair kits (time-sert) appear to be way too long to fit in between the hole and the shock tower. if anyone has experience with this issue id appreciate any advice, not a huge fan of the idea but i don't have many options.
PorterW1111
Florida
drill out the threads set the new plug in place and weld it to the block....then sell the truck..
obviously kidding...
sorry this blows.
CoronaRaptor
CANADA
Are the spark plug threads stripped? Maybe the threads in the cyl head just need to be cleaned better, if not, can you put the old one back in?
G
gn1raptor
NY
this is what it looked like, i removed all of that crud anyways which allowed me to start threading in a new one. that's the only shot i snapped with the little borescope camera i have
bruiser
looks more like the threads are dirty. hard to tell tho, Good luck either way i would leave that to a pro, but the right way would be to pull the head to fix it so you don't get shavings in there
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
nah.... multiple shards of metal mean more sparks. more powaaah.....
actually i too think the threads are just dirty. i dont see any damage on the threads, but we would need to see the other side
PorterW1111
Florida
pull the inner fender liner to give yourself some more room. buy a 90 degree pvc elbow large enough to cover the plug hole attach the other end to a vacumn. drill a hole in the top of the elbow and attach a wire bore brusho for cleaning shotgun barrels cause of the extended pole they screw into, through the hole in the pvc and in to a drill you can now wire brush the threads with the vacumn sucking out as much debris as possible. should def get you into a better place at determining potential damage.
something like this for reference
G
gn1raptor
NY
Thanks for that post
JohnyPython
Canada
I like the vacuum idea.
I have seen a thread chaser for spark plug threads. If you can get your hands on one, use that.
Something I have done in the shop - grind a flat or a groove (longitudinally) on a old spark plug. Apply grease so that the crud sticks to the grease. Take it slow and don’t try to chase the threads all at once. Ensure that it’s going in straight. Check your work as you go.
Looking at your pic, perhaps some of the threads are buggered. The rest looks like crud/old anti seize.
Hope that helps and good luck-keep us up to date.
wharridge
MT
I had one that took the outermost threads with it when I removed it. Using a rifle bore cleaning brush I cleaned what was left, and used an old plug to help clean up/realign the remaining threads. Then used some anti seize to lubricate the new plug going in. Haven’t had an issue since then, 2000 miles ago.
