Strange noise! Need Help
mygreyf150
Colorado
So I just picked up a 2012 screw with the 6.2. I noticed a metallic rubbing sound coming from the drivers side front during acceleration. Has anyone else had something like that happen? If so what was it? I thought maybe it was the intake whistling but checked it and didn't find anything out of the ordinary. Any help would be great!
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
mine was a vacuum leak. it only did it when i was on the gas pedal. somehow the tire rubbed a hole in the hose. after a quick trip to home depot for some rubber tube and a joint connector, everything went back to normal
mygreyf150
mygreyf150
Colorado
I will have to check for the vacuum leak on the hose. I haven't had a chance to really test out the 4 wheel drive yet so I am not sure. I hope it is a simple hose fix that would be cheap and easy
mygreyf150
mygreyf150
Colorado
Dane
Littleton, CO
Pull the vacuum line off of the IWE (plug the line). See if the noise goes away or not.
tltoronto
toronto ontario canada
go to a flat parking lot, put it in neutral, 2wd, crank the wheel to the left so you can see the cv axle, and give the truck a roll from the front left. if the cv is spinning, you have a leak. If not, I say pads.
