chris51080
I’ve decided to do a stereo upgrade in the Raptor. My primary issues with the factory system are a lack of bass, a lack of detail and no headroom.
I’ve already ordered everything, and a quick rundown is in order:
Stereo Integrity M25/M3/TM8 up front
Hertz coax in the rear
MTI dual 6.5” sub enclosure behind the rear seat plus their packaged sub amp
Helix V Eight Mk2 DSP/Amp
PAC A2B converter.
I haven’t installed any of the above just yet, the last of it arrived the other day and I need a good free day to take care of it.
While waiting for all the gear to show up, I ordered block off plates for all four doors, as well as sound deadening from NVX. That made a solid difference.
But, after all that was done, I had the bang and static issue coming from the factory stereo. Took it to the dealer for the DSP update. Had the truck been this good when I got it, I may have saved myself a few grand. Granted, the bass is still lacking, but it’s ok enough that I’m not pissed off with it.
The clarity improved a little.
The headroom issue still exists, there simply is not enough power for dynamic music.
But overall, the factory system with blockoff plates and sound deadening went from a 3 to a 6. It’s shockingly decent. The imaging was always good, but even that seems to have improved a little too.
I was going to install just the sub as my first step, but it wasn’t quite as plug and play as I wanted, so the next step is to go whole hog. I’m hopeful that I can get the system to an 8 or 9.
Point is, boys, don’t downplay just how much of an improvement a DSP tune can improve things. If you’re unhappy with your factory radio, get the DSP update (you did hear a pop followed by static through your radio, right?). Then do sound deadening (I did doors and roof so far) and blockoff plates. For a few hundred bucks and a couple hours time you may be pleasantly surprised.
PAC A2B converter.
