Removal and Installation
WARNING: Always disconnect the battery ground cable at the battery before disconnecting the starter motor battery terminal lead. If a tool is shorted at the starter motor battery terminal, the tool can quickly heat enough to cause a skin burn. Failure to follow this instruction may result in serious personal injury.
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
Remove the terminal cover.
Remove the nut and disconnect the starter solenoid S-terminal eyelet.
To install, tighten to 5 Nm (44 lb-in).
Remove the nut and disconnect the starter solenoid B+ terminal eyelet.
To install, tighten to 12 Nm (106 lb-in).
Remove the nut and disconnect the starter motor ground cable eyelet.
To install, tighten to 25 Nm (18 lb-ft).
NOTE: Tighten the upper bolt before tightening the lower fasteners.
Remove the stud bolt, the 2 bolts and the starter motor.
To install, reverse the removal procedure.
Starter Motor — 5.0L (4V), 6.2L (2V)
Item Part Number Description
1 11N087 Terminal cover
2 W705790 Starter solenoid S-terminal nut
3 14463 Starter solenoid S-terminal eyelet
4 W706414 Starter solenoid B+ terminal nut
5 14463 Starter solenoid B+ terminal eyelet
6 N805024 Starter motor ground cable nut
7 14463 Starter motor ground cable eyelet
8 W704941 Starter motor mounting stud bolt
9 W704942 Starter motor mounting bolts (2 required)
10 11002 Starter motor
