chris51080
After my last outing, and realizing that having a connection to the world available to me at all times is a very good idea, I decided to grab a Starlink Mini, and put it on the truck.
Starlink Mini from Starlink itself, use my link to get $100 off or go direct to them.
The mini is currently in sale for $150, so you could get it for $50 right now.
starlink.com
Savage UTV Heavy Duty mount, purchased from Rugged Radios.
www.ruggedradios.com
48v power supply.
Starlink Power Cable with bare ends
Waterproof connectors to go from third brake light to starlink power cord. (Yes, I wish there were smaller and cheaper options but I got tired of searching).
I will note that if I was doing this from the start, I would just do the Swarfworks third brake light. But, I already have the evil light and didn't feel like dumping another $1k to get starlink sorted. So, for a few hundred bucks, I was able to get this going.
The heavy duty mount has rubber feet on it, with magnets inside. I mounted the included silver magnets to the roof with the VHB tape that was installed on them. The mount isn't going anywhere, and I also have not noticed any added wind noise.
The bulkhead fitting that I added to the brake light was simple enough, just be sure to waterproof it with silicone sealant or a rubber washer. The wiring would've been nice if it came in a 90 degree fitting, but this is what I was able to find.
Power supply does have a decent amp draw, so you will want a relay for it. I used SPV, as I had a few of them laying around.
You need an external power supply, as Starlink wants to see 30+ volts. It will work at 12, but they seem to be happier at 30-40v.
The Starlink Mini antenna is beneath the black plastic cover in the first photo. That cover is simply a protective one to prevent damage from hail and the like. Its transparent to the starlink signals.
One thing to keep in mind is that your iPhone can only connect to a single wifi network at a time. CarPlay utilizes wifi (it starts off on bluetooth but transfers to wifi), so you will need to physically connect your phone if you want to do CarPlay and Starlink simultaneously.
Starlink
Starlink delivers fast, reliable internet at home and on the go. Seamlessly stream, video call, game and more with high-speed connectivity even in the most rural and remote places.
Ford Heavy Duty Starlink Mount
Vehicle Compatibility: 2015+ F-150 (including Raptor and Lightning); 2017+ F-250 through F-550. (detailed list below) The new Heavy Duty Ford F-Series bracket is a significant upgrade to our original design, engineered to mount your Starlink Mini behind the third brake light. This enhanced...
48v power supply.
