I keep hearing random squeeks and rattles which I have pinpointed to the passenger side. It's not the seat, might be the door. Has anyone experienced this and found a solution? I've tried greasing/WD-40ing the doors at all contact points....
That description is a bit general...
Check your glove box - it might be loose if you've taken it apart or have crap in it.
My only noise is some valve chatter on the passenger side - but I'm hoping thats a warramty item.
Also, the weatherproofing at the doors isnt the greatest - i've had mud/snow interfere with a tight seal. There was a post on how to fix that - I'll try and find it and post.
i saw the post about inserting surgical tubing in the door seals if that's the one you mean...
Not sure if its available south of the border, but I use Liquid Wrench.
