Spring Rate and length
Cory s
Orlando fl
I am searching for spring rate and unsprung length of the oem factory coilsprings on a gen1 and gen 2 super crew.
The reason why. I run the full gen2 suspension on my 2018 v8 F-150. With gen1 coilovers. I would like to see if i can run gen2 springs on gen1 shocks to achieve a better ride. The 640lb spring rate of the gen1 coil is to much.
dubya_raptor
If you have a full gen 2 suspension, I would look into getting some gen 2 coilovers. You should be able to find some front coilovers for around $300 or so. Plus the shock bodies from a gen 1 and gen 2 are totally different.
Cory s
Cory s
Orlando fl
Gen2 coilovers don’t fit because of the length. The space between the shock bolt and coil bucket on my truck is the same as a gen1. I have a set of custom valved gen 1 2.5 fox shocks. Just trying to find correct spring rate.
dubya_raptor
I'm pretty sure the gen 2 coil springs are around 533 lb/in. But they are for a 3.0" body shock, so that won't work. I would maybe ask around in the Gen 1 threads to see if anyone makes a spring for the Gen 1 shocks with a lighter spring rate.
My only other suggestion would be to go down to the lowest perch setting on those shocks. That should help with the ride quality. You'll lose some ride height but it should be smoother.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
If you have custom valved shocks they should be valved to your spring rate. Looks like you have them on the top perch which is likely causing your rough ride. The low profile tires aren't helping either.
Cory s
Cory s
Orlando fl
They are on mid perch. Truck with be on 17” methods an 35x12.50r17. Waiting for tires to get here
buckylaine
Moundsville, WV
I'm running gen 2 springs on 2011 Raptor with original gen 1 shocks, bottom perch. The gen 2 springs have a lower spring rate but a 1" taller installed height. So installing the gen 2 spring on gen 1 shock is similar to gen 1 spring at mid perch. Raised the front of my raptor about an 1.5"s.
