SPD turbo adapters and Kooks catted downpipe install tips/help
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by Onemoosehorn, Jul 11, 2018.
  1. Onemoosehorn
    Onemoosehorn Full Access Member
    166
    28
    Apr 1, 2018
    So I have my SPD turbo adapters, stud kit, stud extractor, and Kooks catted downpipes. I’m no stranger to wrenching on my vehicles myself, so I’m not worried about that. But does anyone has any tips or suggestions for the install. Looks pretty straightforward from what I can see. Found some videos on the turbo adapters install, but not much on the downpipes swap. Looking to tackle this job this weekend myself.
  2. awc557
    awc557 Member
    19
    7
    Jun 12, 2018
    i took my truck to a guy that does work on diesels and turbo trucks and he still snapped one of the studs using a stud extractor.
    down pipes going to be mounted to stock exhaust?
  3. Onemoosehorn
    166
    28
    Apr 1, 2018
    Stock exhaust for now. I want to see how it sounds before I decide if I’m changing anything else. My dealer will take care of the install but they are 3 weeks plus from being able to get it in. I have just over 3600 miles on my truck. How many miles were on yours at the time?
  4. k-rub
    k-rub Full Access Member
    431
    184
    Oct 3, 2016
    Tucson, AZ
    I would say you almost have to get a torch to remove the stock turbo studs.
    Take your time and plan on 6-8 hours if this is your first time doing it.
  5. awc557
    awc557 Member
    19
    7
    Jun 12, 2018
    Mine was done with around 18k miles.
    If I were to do it again, I would do the same your doing, Downpipes+adapters to stock exhaust.
    When I got my borla s type, I never thought I would want to change the stock dps down the road.
  6. Onemoosehorn
    166
    28
    Apr 1, 2018
    Thanks. I have one of the of the hand held torches. Someone recommended getting the flexible extended attachment for it. I’m picking that up tomorrow. It’s not a daily driver so time isn’t a factor. Can’t be more difficult than working on my supercharged Tundra was, can it...... lol.
    ---------- Post added at 08:20 PM ---------- Previous post was at 08:15 PM ----------
    I’ve watched/listened to as many videos as I could have before deciding on the Corsa extreme vs downpipes. And then calling every downpipe manufacturer before deciding on which set of those to go with. I’ll see how happy I’m am with it then. I added an AFE intake last weekend. Turbos sound a little better with it.
  7. trophycummins
    trophycummins Full Access Member
    29
    120
    74
    May 29, 2017
    Simi Valley, CA
    We do the studs with a ton of heat. keep the torch on it and hit it with an impact, if it doesnt move, keep heating.
  8. Onemoosehorn
    166
    28
    Apr 1, 2018
    Thanks!! Good to know
  9. Riddick
    Riddick Full Access Member
    166
    104
    Dec 1, 2015
    Sorry Onemoosehorn for a Gen 1 butting in, but wanted to add my .02. I'm no stranger to wrenching either and coming from the diesel world, nothing can't be any worse than working on a Duramax. What I did back in the day was soaked the studs for a couple of days in penetrating oil (like WD-40 specialist), then like trophycummins said, through the heat to it. The hand held torch in the yellow bottle works much better than the blue ones. Never broke a stud and most all came out with very little effort.
  10. Onemoosehorn
    166
    28
    Apr 1, 2018
    Thanks. I’m going to pick up a bottle of Mapp gas to use. I believe that’s the yellow bottle. I’m hoping they aren’t to bad with only 3600 miles on it.
Share This Page
