Spark Plug Change Question
coachhomer
I am changing the plugs for the first time and am a novice mechanic. My question is, once I remove the bolt (red arrow), does the entire housing (green arrow) just pull out? And then is the plug below that?
Thanks!
C
1BAD454SS
You do know it has 16 plugs , follow black wire down by exhaust is other plug , 2 per cylinder . The first one behind passenger shock tower is hardest to get to. Good luck
C
coachhomer
Yes. Thank you. So no real need to remove the electrical connection with the red clip?
Thanks!
C
BenBB
Lots of different places
Thanks!
C
I did remove the connectors, not sure there's enough slack in the harness because that coil pack extends down like 6-8" into the head where the plug lives...
C
coachhomer
Well...so so I guess. I have only done 4 of them. Just haven’t had time. The four I pulled out looked great so I didn’t press to get the others done. It is on my list to do still...
C
