Spare Tire Mount for Pickup Trucks
Discussion in 'Ford Raptor Exterior Modifications Forum [GEN 1]' started by MrGreen33, May 30, 2012.
  1. MrGreen33
    MrGreen33 FRF Addict
    1,480
    366
    Oct 1, 2011
    Rancho Cucamonga, CA USA
    Hi All,
    :birgits_tiredcoffee Wanted to find a way to securely strap the spare tire to the inside of the bed. I want to get a bed cage, but that is not possible at this moment...
    Below is a link to a product I found surfin the net, and wanted to see if anyone has any experience with a this product or a similar one. . .specifically if it serves its purpose while off the paved highway. . .Thanks :peace:
    Spare Tire Mount | PTSTM | Free Shipping!
  2. Prybar
    Prybar Full Access Member
    550
    212
    Aug 18, 2011
    Anchorage, AK
    No personal experience, but it looks like its pretty weak for your needs. I would consider some mounts that could be bolted to your bed bolts. Then strap the tire to that.
    MrGreen33 and BigScott like this.
  3. Blind1
    Blind1 FRF Addict
    59
    12,773
    3,312
    Jan 28, 2012
    Central Alabama
    It looks like a good idea, but I too don't believe it would work for off roading. I can see the bottom slipping right out.
  4. BigScott
    BigScott Banned
    884
    92
    Dec 28, 2011
    goin apeshit on ur ass
    I have to also agree, nice idea for a street truck with a smaller tire. You don't want a 35" tire getting loose in the dirt and especially you don't want a 35" tire comming off in an on the road situation, could kill someone.
  5. Squatting Dog
    Squatting Dog FRF Addict
    8,616
    4,098
    Jun 1, 2011
    Kansas City, MO
    This might be an over simplification.. But why not mount these using the bed bolts?
    And ratchet straps to hold the tire?
    -Greg
    MrGreen33 likes this.
  6. 6.2
    6.2 Banned
    27
    17,807
    1,622
    Jul 11, 2010
    Canada
    There's a few things, there's ones that bolt under the bed, an come through a hole you make, tire sits on there and a v but thing spins on. It's lockable etc.
    And 100% removable so if you need all the space I bed, you can have it.
    Can't remember who makes it though.
  7. BigJ
    BigJ FRF Addict
    5,457
    1,538
    Aug 5, 2010
    I wonder how well those would hold up. You'd need 4, so that will help spread the load, but you're going to have a lot of strap in the air, between the loop and the tire edge. The kind of off roading we typically do out here has as much side to side throwing around as it has up and down. I'd be concerned that I'd never get the straps tight enough to hold the tire down strongly enough so that it doesn't end up moving side to side, and work its way out from under the straps.
    I know you said a rack isn't on the radar yet, but ask a couple of our vendors anyway. If you can't go the full route, I'd bet they can cost effectively build you a simple bar that mounts between two of the bed bolts, with a center post sticking up for screwing a big tire wing nut down to.
  8. BlackMamba
    BlackMamba Full Access Member
    435
    358
    May 7, 2011
    Houston
    I put 4 bed bolts in my bed. Got them at northern tool. Two straps in an X. Tested at Texas Raptor Run. Did not budge. No damage to bed with line x. Eyelets screw out when not in use. Next test is to stack 2 tires. Will test this at a dirt track in about 3 weeks. Can post some pics of my bed tonight. It is still set up as if I was going to have fun rather than driving on I-10.
    Here are my bed bolts. I drilled the holes as close to the frame as I could. For two tires, if the bed metal is stressed, I may buy bigger washers to try to spread the load a little more. I would love to have a cool bed rack, but my checkbook prefers suspension mods and I have zero welding skills (see JTRATX bed), but this worked great. I actually have a total of 6 bed bolts to help tie down cooler, tool boxes, etc.
    KaiserM715 and MrGreen33 like this.
  9. BigJ
    BigJ FRF Addict
    5,457
    1,538
    Aug 5, 2010
    ^^Well there ya go. Never mind then :Grenade:
  10. Raptizzle
    Raptizzle FYT Staff Member
    8,589
    7,436
    Jul 31, 2010
    Southern CA
Share This Page
