GEN 1 Spare tire bed mount help
Roush2012
Fellas I need help. I have been scouring the internet for months for a tire carrier for my bed. I love the dual mount but I don’t want to buy two wheels and two tires. Nfab makes an angled carrier, lex Motorsports makes a carrier that bolts to the 4 bed bolts but none are the kind I really want. I drew up a drawing to where the mount would bolt to the 2 back bolts on each side side of the bed where the bed insert is bolted to. From there it would angle to the bed where the tire would sit on it and then there would be a pad where the hub would bolt to it and hold it an angle. Here is a mock-up just so people get the idea and then a drawing showing kinda what I’m looking to do. I’m no artist so please don’t judge. Please I’m looking for ideas and hoping someone has done something and can give me some insight.
Thanks in advance
Raptor 2014
Well - I had a similar dilemma on another truck that owned.
I used a LARGE gate hinge welded to the bed. I dimpled the bed so the pivot of the hinge would allow the hinge to sit flush. (I could remove the the tire fold the hinge flat and actually use the be if needed).
I also cut a slot in the hinge so when folded to 90 degrees a self made J-hook fit in the slot. The J-hook was welded to a tube attached to threaded bar stock. This fit though the center of the rim and a machined aluminum adaptor secured the tire with a spin on t-handle securing the entire assembly.
It would have been much easier to show pics but I don't have any. LOL
This was easily enough to hold a 100LBS tire. I'm sure more surface area would have been required to hold 2 tires stacked. It depends on how you use your truck.I never had a problem with the one tire mount and I was exceedingly hard on that truck. I broke the frame 3 separate times in different locations. F-250
R
Roush2012
I have looked into the tailgate and actually found a Wilco for sale locally. I just don’t have the money for what he wants for it right now. I can’t believe with all the mounting options that none of these big companies have come out with a low budget simple bolt on kit
badm0t0rfinger
Rocket Man
The Beach
I like the Wilco, but they are pricey. I've also seen the Westcott Design dual spare carrier too and that one looks great. For me right now strapping it down to the bed has worked just fine.
waveslayer
CA
Have you thought about installing the d rings in the bed and just using 2 tie downs? I did that and it works perfectly
My wife thinks I only have 3 guns
shortdeck
I made this simple setup for the bed of my truck. I don’t know the bed bolt layout of the Gen 1 Raptors, so this may not even be an option.
R
Roush2012
Very nice. I was mainly looking for something angled to see the tire just coming out of the bed. I just like that look. I guess if it comes to it I’ll go that route it’s very clean I know SDHQ sells a very similar kit
Pacific Wheel
Reno, NV
@Roush2012 I'm selling my old one SVC built for me. Shipping can be expensive but I'm letting it go for dirt cheap in comparison to what I paid if you're interested. Lays flat and folds up. Locks in place with pins.
R
Roush2012
I like it. That would work great for me. Sending pm
