Spacers a good idea?
AJ-Raptor
Controversial issue but I'm thinking of adding 2-3" high-quality spacers to my stock set up. Reason? I like the tires to be out of the body for a more intimidating stance and better protection as well as a bit more roll resistance off-road.
Aaron
Meme Corps Commandant
WA
Most will say no. However I've seen high quality 2" spacers hold up in some extreme circumstances. Don't skimp on quality if you do it.
t_j
Chicago, IL
I ran trailsport 4x4 1.75" spacers for a while so I could use stock wheels with my new LCA/UCA dual shock setup. No problems, make sure you buy a decent hubcentric spacer and follow the instructions for torquing them down.
Deleted member 12951
Guest
Pretty much a religious argument this topic is.
Anyway they are used a log in all sorts of applications including racing, worth watching:
That was 1/4" spacers that were modified for hub centric and replacing studs with longer and stronger.
The OP is wanting to do 2-3" spacers, 3" spacers??? Maybe 1.25" and hub and done right but cannot see how a 3" would be a good idea on this truck.
t_j
Chicago, IL
Depends on how often he's willing to replace parts, same can be said for 20"s with crazy offset.
They will be safe if they are well made and installed correctly, will they cause faster wear on bearings and other parts sure.
I certainly would not install spacers larger than absolutely required to allow parts to fit without interfering.
Members online
93,145
56,419
TwistAir
Latest posts
