SOLD Raptor Light Package Baja Designs S8 Squadrons S2 - Fogs Grille - Complete!
Robtor310
Redondo Beach CA
Ultimate Ford Raptor Light Package. I just took these off my 2017. The items below are not some cheap import lights. They are the real deal and throw a ton of light! I can verify operation with a 12V power supply at the time of purchase. This is a perfect, professional plug and play setup with waterproof connectors. Harnesses are all setup for a G2 and lead right to the up fitter switches.
Baja Designs S8 30” Grille Light Bar. The 30-inch S8 bar emits 19,050 brilliant lumens via 24 Cree LEDs. All with a low amp draw to put less strain on your battery. A clean aluminum frame with scalloped housing, machined aluminum bezel, and stainless steel hardware protects the circuity from water or debris. The LEDs last nearly 50,000 hours while being fully waterproof and exceeding mil-spec testing for reliability. This kit comes with brackets and hardware that to bolt to your factory mounts without drilling or cutting. Please note that this kit includes a 30-inch S8 in a driving combo beam pattern and the brackets will not accept any other light. The included harness allows you to easily tap your lights into the factory up-fitter switches. Retail is $1023
Fog Light Kit containing 2 heavy duty steel brackets, trim seal, wire harness with 4 Baja Design Squadron Sports and 2 KC Flex Hi Lites with optional removable amber covers. The amber cover matches the factory For Orange Perfectly. The wire harness is perfectly sized for easy install to the factory switches. This is the best looking and best fitting combination of lights out there. Retail is $700 I believe. Can't remember who I bought them off of but it was somewhere on here.
Baja Design S2 Sports. I used these as rear bumper lights but they can be used for anything. I also have 2 removable amber cover, mounting brackets and all hardware. . The customer harness I made is long enough to go from the rear bumper all the way under the hood.
Pics are actual pics of the lights and of my truck.
I don't want to split it up just yet. I want to see if it sells as a package. Id also prefer to sell locally. I can power everything up to show you its in perfect working condition.
SOLD
You know it s good deal. Dont put junk on your truck…
More pics
OEMPlus Raptor
OEM preferred....
Oxnard CA
GLWS, I can confirm this is a GREA deal for quality lights. I too have a similiar set up and spent way more than 1K. Someone needs to jump on this.
