*SOLD* 2012 Ford F150 SVT Raptor supercrew 6.2L in tuxedo black metallic with luxury/navigation packages, power moonroof, front and rear camera system. ORIGINAL, ADULT OWNER, NON SMOKER, Clean title in hand with one documented minor crash of a Honda Civic sideswiping me from opposite direction in 2021. Truck was also bumped into while parked in the right rear in 2023. Definition of a pavement princess with the exception of one trip to Michigan Sand Dunes. All service records/receipts in my possession. Vehicle is no longer driven a lot and don’t have the space to store it so it’s time to let someone else enjoy it. Asking $27,500 OBO
*Vehicle was purchased 6/16/2012 and currently has 131,000 miles. Vehicle was my daily driver and garage kept for the first 11+ years of ownership.
*Exterior is in very good condition with some minor surface scratches, small chips and scuffs on front and rear bumpers. The tailgate step has seen better days and the inside of the tailgate is scraped up. Undercarriage has the typical surface rust for being owned in Northern Illinois.
*Interior is in very good condition with the following exceptions. One pencil eraser sized hole in the rear seat leather. This cannot be seen unless shown where it is. The driver visor Homelink control is missing one of the rubber button covers but otherwise works.
Still get compliments and thumbs up when driving it around. Vehicle drives like it did when first brought home and always well maintained. All scheduled oil changes and maintenance completed by Ford and if something broke- I had it replaced/repaired. Maintenance/mods listed below photos.
*Mods:
Stainless Works long tube headers/free flow cats and a Roush catback exhaust. A Bulldog Tune for 97 octane was also added at that time. This was installed in September 2022 @ 103,000 miles.
Truck Bed has the Ford sprayed in liner
2013 Ford OEM HID Headlights replacing existing halogen headlights (still have have originals)
Morimoto taillights replacing existing halogens (still have originals)
Running boards have been covered with Line-X
Front driver/passenger windows tinted to match rear windows
Rigid pod lights on a-pillars
20” light bar in front grill.
*Some of the Items repaired/replaced scheduled maintenance completed:
3rd brake light replaced in 2016
FUSE 27 repaired 6/2018
Thermostat replaced1/2019
Purge valve replaced 5/2019
Starter and flex plate replaced at 75,000 miles in 6/2019
4 Foxx Shocks replaced at 75,000 miles in 10/2019
Cooling system flushed 10/2019
A/C recharge in 8/2020
100,00 mile tuneup, all plugs and coils replaced, coolant flushed, condenser assembly replaced at 96,000 miles in 8/2021
Steering pump and steering rack replaced at 98,000 miles in 2/2022
Driver/passenger mirrors replaced at 98,000 miles in 2/2022. (11+ years of cycling in/out of garage wore the on motors, unrepairable so replaced)
Passenger power seat switch replaced 2/2022 (switch forward option no longer worked, replaced for full functionality)
Serpentine belt replaced at 103,000 miles in 9/2022
Front and rear differential service performed at 104,000 miles in 11/2022
Transmission fluid replaced/serviced at 104,000 in 11/2022
Transmission cooler lines replaced 5/2023
Driver seat blower assembly for cooled seats replaced 7/2023
Engine Valve covers and gaskets replaced in 4/2024. (Small seepage in one of the gaskets so tried a repair myself and ended up cracking plastic cover…ended up replacing both sides)
Moonroof maintenance/rails replaced 6/2024
Alternator replaced in 11/2024
Battery replaced in 11/2024
Spare tire replaced in 11/2024
New KO3 tires at 121,000 miles in 11/2024
CAB CORNERS were starting to get bad so had them and outer rockers replaced and rhino lined in 12/2024.
Backup camera replaced in 12/2024
Driver inner/outer tie rods replaced 12/2024
New brakes at 129,000 miles in 10/2025
Starter was acting up in 11/2025. Dealer Replaced with ‘new’ Ford part which damaged flex plate. Ford installed another new starter and new flex plate free of charge after Ford engineers determined the starter installed caused said damage in 1/26.
Driver O2 sensor replaced, along with driver lead inlet pipe on exhaust 4/26. (Ford damaged inlet on lead pipe and replaced)
DM with any questions.
*Mods:
