GEN 2 Slight rattle upon light acceleration from a stop
ddpt
Noticed the truck makes a slight rattle upon acceleration from a dead stop when lightly touching the gas peddle.
Hard to describe the sound but it only makes it momentarily after the truck starts moving then it disappears
Tried to replicate when putting the truck in neutral or park and depressing the gas peddle and the sound does not appear. Only makes the rattle when in drive and only when the truck first starts to move.
Anybody experience something similar?
2019 Screw
DDP
exhaust rubbing or hitting something?
darn... forgot all about the iwe there for a few moments.
ddpt
ddpt
I thought the same but when in park or neutral, no sound. I would think if it were the exhaust, sound would be present even when in park.
I thought the same as far as exhaust
DDP
ddpt
ddpt
Try putting it into 4wD next time you hear it... if it goes away, very likely IWE.
that’s exactly what mine sounded like; thought it was a turbo waste gate or loose exhaust beacket.
I saw some videos on YouTube and the initial noise is very similar to what I am experiencing except it is just at the moment the truck starts moving. At least I dont hear it at speeds 2-3+MPH.
It appears to come from the front passenger side engine area. IWE might be it. I'll check when placing in 4×4 mode
Thanks
DDP
WraptorBoy
US
I hear this... "gear" sound at about 1100 RPM, noticable from a stop and as the trans is going through gears 1-3. Comes from the front. It's consistent and repeatable. It happens at prececely 1100ish RPM then stops. Almost like an actuator in sync with the trans at 1100 RPM. No idea what what I'm talking about? Me neither... but I hear it!
